Remote access not reachable
i’m trying to give a friend access. They created an account. And I shared the libraries with them. But my remote access setting says Not available outside my network and under that it says I have remote access through a manual port and the box below is checked but I have no idea what that means.
I tried to read the troubleshooting guides but I need help understanding what to do.
Server Version#:
I am assuming you are hosting Plex yourself? Sounds like you need to port forward it through your router. There are some good guides on how to do this.
I don’t think I have a router
we have xfinity internet but I asked my uncle he says we don’t have one
Just uncheck the Manual port… save it and then re-enable the remote access.
how do you save it? I uncheck but if I leave the page and come back, its checked again. I don’t see a place to click save.
Uncheck the box and scroll down the page, you’ll see
didn’t work. even unchecked it still says the same thing.
Tell us about your network topoly:
PC --> Router/Wifi?
PC --> Wifi --> modem?
I disabled, unchecked. re-enabled. Box is still unchecked but says the same
I disabled firewall too
Im using a laptop and Wifi through xfinity modem
I think we have the same modem, so log in your device and check if UPnP is enabled at:
Advanced > Device Discovery
you mean the xfinity modem?
or do you mean plex settings?
xfinity modem:
Screenshot from 2020-01-05 20-46-17
well gotta put this on hold for the time being. My uncle wasn’t able to log into the place to adjust the settings. His normal password wouldn’t work. He has to go by the xfinity store tomorrow for something else and he’ll ask when he is there. thanks for the help, I’ll get that enabled and then see what happens
Ok. Usually these are the default credentials to log in the xfinity router:
  • Username: admin
  • Password: password (case sensitive)
Enable UPnP in the router and don’t use manually configured port in Plex. Good luck
nope didn’t work. We got into the settings and the modem setting was already checked.
What next?
when I disable remote access and then reenable it…for about 10 seconds it’ll say Fully accessible. then it goes back to not accessible outside my network.
I even disabled the UPnP and reenabled it. No go.
Fire wall disabled, VPN disabled.
What next?
I’ll PM you
