Server Version#: 1.29.2.6364
Server is running in a docker container on an linux server and port forwarding is setup. Docker container is setup with network mode as host.
Local access works correctly without issues.
iOS and Android clients are able to connect and play content remotely, but when attempting to connect to the server with a web client/casting the connection can not be made securely. The only way to allow secure access via the web client is to check Enable Relay, but this method limits bandwidth greatly.
