Remote access not working
Server Version#: 1.24.2.4973
Player Version#: AllPlex Media Server Logs_2021-09-03_12-20-03.zip (6.1 MB)
I have starlink connected to an R6080 Netgear router (with wifi turned off). I have an Orbi system connected to the Netgear, which is what I use for my wifi. My Synology server (which is used for plex) is connected to the Orbi system.
External access will jump back and forth between connected and not connected. However, if I turn relay off, I cannot connect to my server unless I am connected to my home wifi.
Any help?
Ok. I tried something different. I’ve got my router in bridge mode connected to the Orbi. The Synology is connected to the Orbi via ethernet. I’ve setup the port forwarding as suggested. However, I still don’t see anything externally…here are my logsPlex Media Server Logs_2021-09-03_14-12-34.zip (7.9 MB)
My server is a synology…what would editing the LAN on my windows machine do?
I’ll reset and see what happens…
I have discovered that my isp (starlink) using cgnat which is causing my double-nat issues. I’m reading quite a bit about ngrok being a potential solution, but I’m not sure how to make that run on my synology server…
son of a building block! same issue for me. was killing myself. turns out avast decided to add a firewall and enable when i wasn’t looking. while i disabled avast, it only disabled anti-virus, not the new firewall that i didn’t know about.
soon as i disabled that, lights came on and i could now connect.
hope this helps someone.
I wish it was that simple for me…I’m still stuck at my isp using cgnat, which is preventing me from external access due to double-nat that I can’t control…
@primetime34
Most ISPs will let you have to a real IP address for a small fee ($5 in the US).
Have you considered that option?
Not an option for starlink (at least not yet)…hopefully soon though
