Server Version#:PlexMediaServer-1.41.3.9314-a0bfb8370-armv7hf_DSM7
For years PMS installed on my NAS Synology 214+ was working fine or if I had issues I was able to resolve. But this time I’m lost. DMS version installed is DSM 7.1.1-42962 Update 7
I already contacted Synology support team who confirmed that the NAS is accessible externally via port 32400. However acess via https is not possible and trying access via http I’m able to login, but PMS cannot be found. SYnology support team suggested to contact now Plex support.
I’m using Let’s encrypt certificate, which was working fine for now.
When I’m logged @ plex.tv in I cannot see the PMS on my NAS. I see all my other devices (PCs, TVs) but not the Synology NAS.
You are going to do the same thing, except use the commands listed in the Synology support note.
Copy all three commands into the same task.
cp -af /usr/syno/synoman/webman/modules/PkgManApp/PkgManApp.js /usr/syno/synoman/webman/modules/PkgManApp/PkgManApp.js.bak
rm /usr/syno/synoman/webman/modules/PkgManApp/PkgManApp.js.gz
sed -i 's/SYNO\.SDS\.htmlEncode/Ext\.util\.Format\.htmlEncode/g' /usr/syno/synoman/webman/modules/PkgManApp/PkgManApp.js
See the screenshot below. The text wraps due to the small window size and long paths.
Step 2: Run the task.
Right click on the task and select Run.
It takes maybe 3 seconds to execute.
If configured to do so, you’ll receive an e-mail with the results. Current status: 0 (Normal) means it executed properly.
Step 3: Logout / Login
You must logout/login to the NAS for the change to take effect (not mentioned on Synology forum thread).
You should now be able to use Package Center the same as before applying Update 7.
No chance to connect Plex via NAS.
Something is problematic with QuickConnect (see screenshot).
Is there a problelm with http instead of https connection?
