Remote access offline
Nothing changed im my house or my computer . i can not get remote access to connect . I see the ports being opened in the router . i even changed the port and i see the new port being opened . i did not updates or changed to the plex computer . Am i the only one seeing this ?
Having the exact same Issue tried a bunch of stuff nothing worked went back to my original settings that were work now I’m waiting for some type of fix myself.
double check that your router did not give your computer on the network a different IP address… Sometimes this happens… and can be avoided by using the IP Reservation (called different things on different routers) settings in the router…
If this is not the case, then I am unsure what your issue could be… (I recently did learn however that my ISP actively blocks things in the 4000 range of ports… it’s at least possible that your ISP has chosen to block that port, so trying to a different port could also fix your problem)
