Im running pms on an nvidia shield, i cant seem to get remote access to work since changing isp from talk talk to nowtv. (im now using the nowtv router). Ive reserved ip address, ive forward to external port set at 50000. When i enable remote access igo goes green for 2 seconds the turns back red not accessible from out side your network. Ive created a firewall exception. Any one have any ideas what to do with thus Now tv hub 2 router?
Did you check to see if you are on CGNAT?
When you go to http://www.whatsmyip.org/ the address should match the WAN address on the router.
Having the same issue
Hi yes ip is the same.
Stefan mobile
