Remote Access remains enabled for only 10 second
Server Version#: 1.41.9.9961
Lost remote access after server update. QNAP NAS plex server behind Nord VPN
Been running flawlessly for several years but after the latest server update, Remote access if active for only a few seconds after enabling it VPN is functional and functioning
That’s just how the remote access check works. Plex assumes, remote access is working – and only changes the status after the test/check completes. Consider it’s not working at all.
With a VPN, you’ll be mostly on your own to fix this, though – sorry.
