Remote Access Troubleshooting Arris NVG589
I’m a networking novice trying to set up remote access for my plex media server. I keep getting the ‘Not available outside your network’ message and have tried checking the manually specify public port box.
The remote access trouble shooting page suggested making a static IP for my server and port forwarding but I’m not sure if I did this correctly since I still do not have remote access.
Any suggestions would be appreciated.
I’m using an Arris NVG589.
Server Version#: 1.41.3.9314
Doing so is not a guaranteed path to success.
The truth is that most new internet access contracts put their customers behind Carrier-Grade NAT
And if that happens, you are in trouble.
Is AT&T your ISP?
Here’s a guide on setting up port forwarding: Set up Port Forwarding for NVG589 - AT&T Internet Customer Support
I’ve the BGW-320, and the screenshots seem similar. Here’s how to set up port forwarding on a BGW-320: Changed ISP - No Remote Access with AT&T BGW 320-500 - #3 by FordGuy61
I don’t believe my ISP is using CGNAT. I did a traceroute and didn’t see RFC1918 or RFC6598.
Thank you for your help.
I was able to follow the second link but still no remote access.
