Remote Access works for a few seconds then stops
hahahaha Good
Okay, so this is weird. my friend is streaming something from my server right now. But, plex says this" Not available outside your network
Your server is signed in to Plex, but is not reachable from outside your network."
Just reboot it and will see if anything changes
it is rebooting now
Same - " Not available outside your network
Your server is signed in to Plex, but is not reachable from outside your network"
can you share a screenshot?
Sorry but i cant read. Its too small
sorry, let me try again. I was trying to be fast.
Thank you. Lets first try disabling the firewall ( you can enable it later again)
sudo ufw disable
Uncheck the Manually specify… and click retry / re-enable the remote access
disabled
Same. up for a few seconds then back down
Uncheck the Manually specify … and click retry / re-enable the remote access
same. up then down
hang on.
I think I need to reboot.
for the firewall to be fully down.
rebooting now.
You can check it with
sudo ufw status
confirmed inactive
