Remote access
Server Version#: 4.87.2
What is the prime reason “Remote Access” disappear?
Once a week I have to disable the Remote Access and then enable it again.
Your router most likely removes the automatically established portforwarding after a few days.
See if a simple stop and restart of PMS can also restore remote access.
If it does, it confirms my above suspicion.
Switch to a manually created port forwarding. https://support.plex.tv/articles/200931138-troubleshooting-remote-access/
I’ve always been using manual port forwarding.
All local IP are static.
