Remote control.
Hi, I use Plex for a long time.
But, I have problem to compatibility to using remote control on Android.
The Plex Media Player (remote control) no has possible to change audio, only subtitle.
Using same control, has possible change audio on Plex Home Theater
The program on Iphone working, in both program, but on Plex Home Theater the time freezes.
Any Solutions?
Server: Ubuntu 16.04.3 LTS - Plex Media Server 1.11.3.4803
Players:
Plex Media Player 2.5.0.792-1bc7f225
Plex Home Theater 1.4.1.469-47a90f01
Plex for Android 6.13.73458 (974b0628)
I have recreated the issue and filed a bug report.
Do note however, that you can select a different audio stream in your Android app before starting playback:
PHT is no longer supported. Consider using PMP or at least OpenPHT instead.
I hope they fix this in the updates.
