Remotes; what are people using?
Hey guys,
As above?
Harmony 700.
I made a plugin to use a wiimote using the built in bluetooth of the Rpi3 and you can get those dirty cheap
Personally I’ve always preferred using Mini keyboards, connected to the RPi through an RF USB dongle.
This gives a wireless connection without dependency on either IR (line of sight) or BlueTooth (protocol variations).
Best regards: dlanor
Harmony Touch that works with most of my devices, together with a flirc dongle.
MeLE F10 Deluxe
I really need to dig into the files to customize/enable the other buttons on it though to really unlock its full usefulness. I just haven’t had the time.
Yeah I have a few of those,
@sremick said:
MeLE F10 Deluxe
I have one of these to :slight_smile:
What I really want is something like this
But thanks all for the feedback, I think ill stick to the nexus/ Alexa/ iphone for now :slight_smile:
For what its worth, I’m not a fan of the Harmony, I think they are over priced for what they are.
Have you done any custom keymapping to enable the other keys on the main (not keyboard) side?
That’s why I get them used on Ebay.
Yeah I did, it works very well. I was using it as my bedroom TV remote/ HTPC control.
Ill have a look :slight_smile:
Would you mind chiming in on this thread and sharing what you learned/did?
http://forums.plex.tv/discussion/201421/custom-keymaps
i7 Rii mini and its very awkward it almost works, what i really need is the home button to go straight to the main home screen no matter where i am. Have any of you had this problem?
I have this in my remote.xml file
Play FastForward Rewind Stop Left Right Up Down Select Back #ActiveWindow(Home) ActiveWindow(Home)
Sorry for hijacking this thread is this ok?
Regards
Steve
I use this little wifi airmouse keyboard remote with IR learning.
I also have this little probox2 remote I’m going to use a with a dual boot emulation system.
<keymap>
   <global>
     <remote>
       <yellow>Play</yellow>
       <blue>FastForward</blue>
       <red>Rewind</red>
       <green>Stop</green>
       <left>Left</left>
       <right>Right</right>
       <up>Up</up>
       <down>Down</down>
       <select>Select</select>
    </remote>
    <mouse>
     <rightclick>Back</rightclick>
    </mouse>
    <keyboard>
     #<home>ActiveWindow(Home)</home>
     <key id="172">ActiveWindow(Home)</key>
Regards
Steve
@Steve_SansumWright where’s the rest of your XML code? You don’t close the rest off.
My apologies I was pasting from the terminal. I have attached the xml file.
Im using Ubuntu Server 16.04
ZFS Raid 5
Plex Server Version 1.3.4.3285
Rasplex 1.7.1.137
I originally use OpenElec and Plex as a DLNA server which strangely the remote worked as it should. But I really do not want to go back to having no media info. Apart from this Rasplex runs wonderfully on my mildly overclocked Pi3
