Removing duplicates?
I copied many movies from a USB drive to a RAID drive, then attached the new drive and removed the old USB drive. Plex now shows both copies (total = 1150) as duplicates. Is there an easy way to remove the no-longer-connected movies from Plex without having to delete them one at a time? I’ve rescanned twice…
Try emptying the trash for the library in question. Select the vertical ellipsis when hovering over the library in the side panel, then Manage Library -> Empty Trash. That should cause the server to remove references to any files which it cannot find.
Bea-utiful! Thanks, that did the trick.
No problem, glad it worked.
