Server Version#: Version 1.15.3.876
Player Version#: Latest Samsung Smart TV client app
Instead of resuming, from the spot that is shown before I hit play, it plays from beginning. I have been using Plex from this TV for many years and have not had this problem before.
I did switch to DD-WRT on my WRT1900ACv2 router but not sure if this is why.
I did log out of both the server and client and then restarted/relinked them but resuming still failed.
I am a paying plex pass member. Please advise ASAP if there is a DD-WRT router setting that needs to be set.
I was running OpenWRT on my WRT1900ACv2 router as well as the factory Linksys firmware and had no issues with those.
Same issue here at well with my Samsung TV. Do not remember when it started, but I know its been recent. TV app used to resume fine in the past but now every movie I watch on the computer and then resume on the TV will automatically start from the beginning, despite showing a saved resume position at the movie screen.
I switched to the OpenWRT firmware I was using in my other router partition and the resume feature is working again⦠cancel that⦠it works for some movies but not othersā¦
I will downgrade my plex server for now
If this bug doesnāt get fixed before my renewal date, I donāt think I will continue to be a plex pass member.
Hello Darcilicious
What do you mean by āit cannot be fixed because there is no developer to fix itā?
No developer at Plex or Samsung?
Regards
Bernard
A seamless interaction between mobile devices, computers and smart TVs are one of the most important features of PLEX til now. If Plex relies on free developers who will not be substituted after they leave (for what reasons whatever) Plex users will not longer invest in the Plex pass.
So please hire a developer who is able to continue the work on Samsung TV.
No idea, you would need to ask @orca, the developer, if he has or is willing to make the code publicly available. He may or may not still be monitoring the forums.
Hi everybody,
That problem is a server software problem. I downgrade the server to version 1.14.0.5470 and everythings came back right. All the videos now can resume from where it was left on last time I play it back. I found that old version on the web site www.01net.com but you can find other else on some site with few search on many site that offer to download software from.
Best regardsā¦
So this is clearly a server side issue as it was broken by a server side update (down grading confirms old versions of the server side still works). So being a server side issue we should expect an update to address this right? The only reason I have Plex is so I can access my collection easily from my Samsung TVs
There was a bug on the server side; that was fixed so that Plex developed/supported clients would work correctly. Unfortunately, client apps that are no longer being maintained were incorrectly coded and now that bug is showing in those (two?) clients.
So is there a plan for Plex to release a āsupportedā version for Samsung? It seems a little crazy that an āunofficialā Plex app has been available on these TVs for years and years. It certainly has all the official looking Plex branding. You can understand why users are surprised to find out itās not supported by Plex
Can the Plex Media Server detect what Plex client app connects?
I took a peek at the logs and saw this, which shows it can detect when a Samsung
TV connects. Maybe that alone is enough :
Apr 20, 2019 22:51:56.573 [9124] DEBUG - [Now] Device is Samsung (TV UN58H5203).
Apr 20, 2019 22:51:56.573 [9124] DEBUG - [Now] Profile is Samsung
pseudo code:
If a Samsung TV Plex client app connects
then use the server code that worked with it
else use the latest code
Same problem here. It started a couple of server updates ago (a few weeks back). Annoying and I hope it gets fixed. We have 3 Sumsung smart Tvās in the house and it affects two of them. The third isnāt a smart tv - runs a firestick and thatās ok. One solution would be to get a Firestick, but they only work if you have an Amazon account. Not really an elegant solution I admit.
Same problem here, we have three TVās, two are older Samsung TVās and are being affected by this. Iāve used this client for years without issue, it plays all content much better than the official app for my newer Sony Android TV, that client looks pretty but is a bit useless when it actually comes to playing content.
