Revisiting SMB/UNC libraries and auto update / change detection
PMS latest version.
So it seems there is hot debate over the years about using UNC paths for your media libraries using SMB or NFS on a remote server. Sometimes NFS, sometimes another windows server. It seems some people have said the change detection works, some say it doesn’t. Sometimes they say ‘generally’ works, ‘generally doesn’t’. What is ‘generally’?
So my question is this. It’s October 2020. A lot of these threads are years old.
  1. Has this been fixed/improved upon?
  2. Does Plex detect changes to a library now when using SMB and/or NFS?
  3. Are there certain configurations that work reliably and other configurations that don’t? If so, what are those configurations.
  4. Are mapped drives a workaround?
  5. What about symbolic links? Is that a viable workaround? (windows symbolic links)
anyone? This seems to get asked a lot without a real solid answer.
would still like an answer to this please.
Do plex staff even monitor the forums? They certainly don’t answer emails and have no phone number.
I used an SMB share for Plex and many versions ago it worked perfectly though not anymore, my workaround is to up the refresh library interval. Honestly, with an SMB share there are many more moving parts.
It doesn’t. If it worked for some via some sort of fluke then that all it is. either the networked drive system updates the mtime to the host computer or it doesn’t. If there is some systems that does that then ok but Plex doesn’t control it.
