Server Version#:1.20.4.3517
Player Version#:4.43.4
I’ve been using IMDB ratings and Plex Movie (Legacy) agent forever.
This week after an apparent update, I’m seeing RT reviews in all my IMDB libraries.
The ratings are still IMDB for existing and newly added movies, but these reviews have appeared.
This coincided with the new player GUI.
I like a lot of the new changes but what’s up with the RT Reviews?
I tried changing agents and other options (&plex dance) but these reviews persist.
Hoping this is a bug and not a “Feature”
Noticed a similar issue mentioned in this thread.
This script is getting me by but I wanted to report the issue.
Would also like to find a way to get rid of these reviews.
Freaking annoying.
On top of that, I trust the US election process more than reviews from rotten tomatoes.
Please give us a way to disable this.
In fact RT reviews are very useful. The lower they are, the better the movie is. That thing is so biased that wouldn’t call it rating.
There isn’t such a thing as an IMDB library, you can chose to use IMDB ratings but that only affects the ratings and nothing else.
There is an open feature request to disable reviews: Disable reviews
I put “IMDB library” in the title to speak to the fact I’m using IMDB ratings. I didn’t expect you to take it literally. Can you comment on whether this behavior is intended? (RT reviews appearing)
In the past, reviews only appeared when you selected RT ratings.
I’m aware of the feature request thread and have voted. thx
Thank you. My search was sub-par.
