"Run a partial scan when changes are detected" on Nvidia Shield with Synology NAS not work
Hi everybody
The Plex Server is installed on my NVidia Shield and I have all my movies on my Synology NAS.
All runs perfectly exept the function “Run a partial scan when changes are detected”.
Have someone an idea what the problem/solution is?
I have a feeling that this is a limitation of file access via SMB.
See: https://support.plex.tv/articles/200289306-scanning-vs-refreshing-a-library
Note : In most cases, this should work for content on local filesystems. It will generally not work for network shares mounted via SMB, NFS, AFP, or similar.
I have mine set to Scan My Library Periodically: Every 15 minutes.
Thanks Craigycham
I almost thought that. I believe I have to scan the same like you.
