Server Version#:1.18.3.2156
Player Version#:4.15.2
After the 4.15.2 update for the samsung app was pushed out somewhere about 12/30/2019 the Samsung TV (MODEL NUMBER: UN65NU8000FXZA) will no longer stream 4K content. Everything was working perfectly just days before. When I attempt to play a 4K movie, it the screen simply reads “buffering” with the spinning clockwise ring.
How do we roll back this defective build of the app?
I too am having issues that started about a month ago with just my Samsung player. Started about a month ago I continually get Player_error_connection_faild(avplay) Running 4.15.2 on the Samsung and server 1.18.3.2156-349e9837ePlex Media Server.log (4.2 MB)
Now 20 days, and still not a response from anyone from Plex about this defective build. I noticed a new version was released on 1/21/2020, but that did not fix the issue. Please respond.
Here are the files you requested. As stated initially, This movie and the others, all played perfectly before the 4.15.2 update. Now, when I attempt to play them, the simply pop up a message that reads Buffering, and nothing more will happen.
Yes, I did. However, it appears that once you exit the app, the setting reverts back to disabled. I re-enabled the option and re-created the log file. Plex Media Server Logs_2020-01-24_15-39-49.zip (4.6 MB)
I just saw this and I think I can repeat the error and hopefully the workaround (sorta) that I have resorted to. I will try to capture this on Sunday and will send it to you.
We’ve had several people test and so far we are unable to reproduce the issue regarding 4K playback. Have you tried uninstalling and reinstalling the app incase it was a bad update?
Can you playback a different 4K file and get me a new log?
