Server Version#: 1.20.1.3252
Player Version#: app version in Samsung settings 5.1.0 (client version 5.1.3 in Plex)
Plex keeps freezing when trying to play a video from my server (laptop) and also just randomly, e.g. when changing clock to 24h, enable log to media server, reset app, etc.
Can’t do anything. Do know how to provide more logs…
Have reinstalled, have deleted and installed again, to no avail
If you dont know. If a app locks up/freez on samsung tv you can just hold down the back button on the remote several seconds and the app will be killed. If this does not help you can reboot the TV by hold down the powerbutton on the remote until a samsung logo appears (take about 2-5 seconds)
When the plex logo is stuck on the screen, does pressing the directional buttons on the remote make the clicking sound? You’ll need to turn it on in settings first if it’s off. You might also need to wait a couple minutes before you hear clicking.
I’m having the same problem. Plex app in the TV is useless. Most of the time won’t even load.
I have to remove power from the TV to force it to reboot and then the app starts working again, but after some time it gets slow I have to reboot the TV again.
I’m running Plex Server 1.21.1.3795-ee64ab56f (on Debian on a 6-core CPU with 16 GB on RAM).
The TV is Smart TV SUHD 4K Series 9 (UN55KS9000FXZX).
The TV is connected via Ethernet to the same switch where the comptuer running Plex is connected to.
