Screen freezes intermittently and parts of the screen gets pixelated
Server Version#: 1.32.4.7195
When playing back certain software, the screen intermittently freezes and parts gets pixelated when it resumes. The freezing is random and lasts for half a second or so. Another version (different source) of the same show works fine and previous seasons works too
I don’t think it’s a buffering issue as I do not see the orange circle moving.
Attached is the logs from Plex which I hope wil shed some light.
Plex Media Server Logs_2023-07-02_19-11-59.zip (59.5 KB)
Thanks!
“Statistics” don’t tell anything.
Need the full logs ZIP file ---- Especially “Plex Media Server.*.log” files (DEBUG logging enabled, VERBOSE logging disabled) which include the playback.
Here are the logs I downloaded after playing
Plex Media Server Logs_2023-07-03_11-12-35.zip (64.3 KB)
Plex Media Server.*.log files please ?
It looks like you deleted everything I need.
I can’t do anything with what you gave. Sorry.
The files should be about 3-5 MB when zipped.
I deleted all the files in the *\PlexMediaServer\AppData\Plex Media Server\Logs folder about a week ago thinking they were not needed.
Then I disabled Debug.
The logs I attached was what was captured after I enabled debug and went on the play my show.
Is there anything I can do now to get the required logs?
The easiest way to do this now is:
  1. Confirm DEBUG logging is enabled (no harm if you leave it on. Max space usage is 100MB). Also confirm VERBOSE logging is disabled.
  2. Restart PMS
  3. Give it a minute or two to start (typical Syno startup)
  4. Now recreate the problem
  5. As soon as it fails – Settings - Server - Troubleshooting - Download Logs
  6. Attach the ZIP file it gives you here so I can see it.
Attached is the log!
Plex Media Server Logs_2023-07-03_16-18-24.zip (92.7 KB)
Thanks!
Hopefully I got it right!
Plex Media Server Logs_2023-07-03_16-36-53.zip (201.6 KB)
Hi Chuck,
Did the logs show anything?
I’ve added logs after encountering the problem on two more different shows
Plex Media Server Logs_2023-07-09_20-01-53.zip (4.2 MB)
@ChuckPa
I’m still facing this issue after installing 1.32.7.7571.
Attached are the logs
Plex Media Server Logs_2023-10-04_10-47-33.zip (3.7 MB)
