Sealab 2020 vs 2021
Server Version#: 1.40.4.8679
Player Version#: All
I can’t figure out how to have both Sealab 2020 and Sealab 2021 in my library. Plex appears to get confused and it’s conflating the two. The only series it shows is 2021. So, I don’t have a series poster to Fix Match on.
Is my only recourse to delete/move 2021, get 2020 set up, then put 2021 back in place? I’ve seen mention of a metadata file in the series folder. Is there a relatively easy way for me to create/edit that, so that Plex can figure out that they are two different series?
TIA,
Drake
See Library Folders no longer updating - #5 by OttoKerner
I promise I did a search before posting my question :slight_smile:
Thanks for the pointer. Did The Plex Dance ™. Then, had to Fix Match on Sealab 2021, searching for tt0278877. One more browser refresh for it to actually show up.
Appreciate the help,
Drake
