Select a quality to play.
I have a movie..
"Fast & Furious 6"
1080p
720p
On the Plex.tv site I can select what quality I would like to play. On the XBOX One you can't select quality it just plays
On the Xbox One you cannot select a quality to play.  Devices without the quality select function will automatically select the first quality that appears in the XML. (You can view this by selecting info from the movie screen under the ... menu then clicking the link to view xml)
Can the Devs shine in here and see if this feature will be coming soon?
We are working on improving this so that the 'best' option is automatically chosen.
As always, we don't comment on timelines. Sorry!
Ok, thanks Dom C for a quick reply! We appreciate your response! have a good day!
