Computers on a network are essentially floating in a pool with no specific place to be. A router knows where they are and can send and receive “stuff” from them, but their location is pretty fluid.
Assigning a static IP address locks them down into one place. This allows your router to always know where that computer is. Assigns it an address so to speak. That’s the first part… locking down the address of your server so the router doesn’t accidentally lose track of it.
Now, there are several ways to get into the computer at it’s new address… There’s the front door, the kitchen door, the side door, the garage door… Those are the ports.
Port forwarding basically tells your router “When you receive information of this type, send it on to this specific door of this specific house at this specific address.”
Your Shield has a door open waiting for Plex stuff. That door has a default number on it, which is “32400”
The hard part:
The first thing you should do is dial into your router… if it’s a Netgear, it’s pretty easy. Open any browser and type in routerlogin.net. Most routers have this info posted on a label on the unit somewhere. There will likely need to be a login and password entered here, which should be on the label. I’d be surprised if it wasn’t “admin” and “password”
Google the instructions for assigning a static IP to your device from the router admin page. I’m not really sure what the specifics are, as they vary from router to router, but there should be an area for assigning static IPs. It might be under Advanced > LAN Setup > Address Reservation
Odds favor your IP Address should fall in line with other devices already connected; 192.168.1.XXX, with “XXX” being the custom number you assign.
Once you’ve done that, there should be another area for port forwarding. This part gets a little trickier. I’m not sure where you find it. Maybe Advanced > Advanced Setup > Port Forwarding? Here you’ll wand to add a custom service called “Plex” with the TCP Protocol. The IP Address is the one you assigned earlier, and the port will be 32400.
Once you’ve done that, head back on over to Plex under Settings > Server > Remote Access and check the box for manually specified port. At this point, you should probably power cycle the router and the Shield.
It may take a few minutes for the connection to bind, but once it does, you probably won’t have any issues like this again.
