Yep, its a problem that’s been around forever, and hasn’t been solved. Nope, I can’t backup and uninstall reinstall as I can’t get to server settings. Neither can I download logs as obviously I can’t get to server settings.
I’ve tried a few things like administrator install of update.
Seriously unimpressed that this issue has been ignored for so long.
I’m having the same problem. I tried the linked solution and no luck. I’ve also tried running as admin as it was suggested that might be a solution. That didn’t work either. How do I go about getting this resolved?
I havent got that problem when i downgraded, maybe you can try and setup trakt for yourself it can keep a track of your watched status. It can pull or push whatever you have watched to plex or to the trakt website
Same issue here update to a new version and bam it breaks PMS. Downgrade to 5102 and everything is kosher. I try to upgrade to each version as it comes out with no luck. No response from Plex staff is worrying as it seems like more then just a few people have been experiencing this major issue.
Likewise, solved my issue. Took ages to find solution and had the same problems as those posted above.
Could revert to 1 year old version OK. Every update thereafter tried and had library/ playback and no access to settings. Thank you
Hello Otto: I can’t access any settings in the web interface to make sure drive letter path is correct. I see no entry relating to the path in the registry either.
Thanks Otto. That link allowed me to see the “unclaimed” server and I can now see my media files in the app. How does it get into an “Unclaimed” state? Anything I should do to prevent this?
