I do not appear able to use Plexconnect if I select "Disable remote access" on my PMS.
Is this just how it is?
Is the PMS local or remote?
Local.
Jailbroken aTV2?
Jailbroken aTV2?
No, aTV3.
What is your settings.cfg? Is GDM enabled?
enable_plexgdm = True
enable_plexgdm = True ip_pms = 192.168.1.10 port_pms = 32400 enable_dnsserver = True port_dnsserver = 53 ip_dnsmaster = 192.168.1.1 prevent_atv_update = True enable_plexconnect_autodetect = False ip_plexconnect = 192.168.1.10 hosttointercept = www.icloud.com port_webserver = 80 enable_webserver_ssl = True port_ssl = 443 certfile = /var/lib/PlexConnect/assets/certificates/iMovies.pem allow_gzip_atv = False allow_gzip_pmslocal = False allow_gzip_pmsremote = True loglevel = Off logpath = . ip_webserver = 0.0.0.0 log = Normal
I just shut it off on one of my local PMS (disable remote access) and PlexConnect is still picking it up as a local GDM and I can watch local content. Fill this out so everyone can assist you further:
Also list if you have any recent changes to your home network or PlexConnect host.
I just did the same, and it works. I then closed the PMS port on the router, and it still works.
I've either messed up somewhere, in which case I apologize profusely for the inconvenience, or the problem only shows up at some later time when a re-authentication attempt behind the scenes has failed.
Let's tentatively consider the issue closed. I'll post again if I re-encounter the problem.
Thanks, wahlman.j!
That was quick: I revisited the PMS "Remote access" tab, got an exclamation mark on red background as I did so, and "PlexConnect: No Plex Library Sections Available" ensues.
I'll provide log details after work.
