Settings to receive correct movie metadata information
In the last month or two, all of my metadata information for my movies has changed to completely inaccurate information. The movie poster, background art, etc., is incorrect and I don’t know what could have happened to cause this. What metadata agents should I use to get the highest quality information? I can’t imagine that I’ve named my movies incorrectly because as I’ve said, a month or 2 ago, all metadata information was absolutely perfect. Please help!
Can you give any examples of movies with incorrect info? What their filenames are and what's incorrect about the movies?
Also, if you could click on the edit button for the section having problems and check the scanner and primary metadata agent settings (should be movie and freebase respectively if they're set to the defaults), and then click the gear icon to check the metadata agent settings for the selected agent that would be helpful as well.
Hey,
Thanks for your help. I found that by unmatching the information for the movie and then searching for the movie in free base under “incorrectly matched”, I can now get the right info.
