which PC did you get?
Beelink S12 Pro
The S13 was also released recently, not sure how much better it is at Plex stuff, but it does have a better processor
EDIT: Oh, one other thing I changed, I moved my Movies library from /NVIDIA_SHIELD/Movies to just /Movies. Not sure if that was a factor here but I did want to mention that just in case.
So are we just not going to get any info on this issue?
Same Problem here with Plex Media Server 1.41.3.9292.
@drzoidberg33 can you help for fix the auto search?
@Plex Team: Please help, old Plex Version works fine, newer one not.
Any updates on this?
Anyone figured out a fix?
Iāve found that manual update in Shield Plex app often does show a change. I need to stop the app and after reopen the new files show.
It sucks, please @Plex Team. Please fix this!
Has anyone got server logs?
Here is an example (just copied 1 file, nothing appeared in plex).
Plex Media Server.log (1.7 MB)
Out of interest what settings do people have within Settings > Library?
I have setā¦
Scan my library automatically: disabled
Run a partial scan when changes are detected: enabled
scan my library periodically: enabled.
I have a few tv episodes that I need to add to my library tonight.
Thank you. On my old server I just did a manual scan, never bothered with the auto scan feature.
I will try that out tonight
I tried tonight, not too sure that this will help @drzoidberg33.
My setup is Nvidia shield pro 2019, Plex Server # 1.41.4.9380, media files are stored on a NAS.
NAS drive is setup on the Shield as a mounted network storage.
20:59
Log files deleted
/NAS/TV_Shows/Show Folder < Created
/NAS/TV_Shows/Show Folder/Season 1 < Created
File transfer to NAS started
21:10
File transfer to NAS finished
21:15
No log files
Library not automatically updated
21:30
No log files
21:31
Manual scan started
Season appears in Recently Added
Log files created (analysis, scanner matcher, credits and statistics)
I have tried with almost every combination, but nothings works unfortunately.
I have the same problem as described in this thread so hopefully Plex soon will step in an look at a fix, since i donāt think there is much we can do.
@drzoidberg33 Any News from your end?
@drzoidberg33 just for further info, I added another season in to the show folder that I created the other day.
It was left for over 2 hours, and the season never appeared. When my maintenance window kicked in at 00:00 (Update all libraries during maintenance is enabled on my server) the season appeared.
