Server Version#: 1.25.2.5319
Player Version#: 8.28.0.30077
I got a Shield TV Pro recently and for the most part it’s the best 4K streaming device I’ve used. But in Plex I’m having a lot of issues. They may not be specific to Plex, but it’s the only app I use on it.
From time to time the system will totally freeze requiring a hard restart.
Often, just about every day I use it, there are times that it will take 5 seconds, to over a minute for the system respond to a button press on the remote. If I’m patient it will eventually sort out whatever the problem is and will go back to mostly normal, if not a little slow, operation.
Also I have the same issue as another user posted here.
https://forums.plex.tv/t/shield-tv-pro-with-plex-player-8-28-videos-start-but-never-actually-play/769350/2
I’d like to use the server capabilities to run a backup server, but can’t imagine how that would work given the performance issues.
Any suggestions?
Thank you!
