Showing episodes instead of series
Server Version#:1.40.1.8227-c0dd5a73e
Ok, I had to move my server off one pc and on to another. Somewhere in this process the database corrupted. I managed to fix that, and now I have a new problem that’s not super important, but very annoying.
My server no longer shows series. it shows episodes. For example, If I were to add Game of Thrones, they way it used to show up is on “Recently Added..” as Game of Thrones, and there’d be a thumbnaul and underneath it it would say 8 seasons. And then you could open that up, and select a season and go to that screen and then pick your episode.
Now, Under “Recently Added…” it would just show Game of throne S01E01 and then Game of Thrones S02 E07 and so forth.
You can click off reccomended and on to library. And then use the drop down arrow to select folders. That will put them into literal folders.
I want to fix this back to how it used to be!!
Please help!
(Side note, I know neither img shows Game of Thrones, I was just using a popular title to convey issue)
Also, its only one library that does it.
Your screens shots of the Anime library show you made it as an “Other videos” library instead of a TV library.
I can tell from the icon next to the left of the library name in the sidebar.
Other Videos is like for home movies or other types of single videos.
Only TV libraries have the concept of a Show/Series as a whole with seasons.
Ill give that a try… I kinda figured i just goofed somewhere simple and am overlooking it.
That was it! Thanks so much!
