(Skip) Intro Not Working / Detected After Fresh Install
Server Version#: 1.25.1.5286
Player Version#: 1.39.0.2753-d48b8c8b
Hello,
A few days ago I completely reinstalled Plex and readded the libraries using the latest format.
Now, it does not detect any intros for TV shows.
I went through this guide, but there is nothing new or different: Skip TV Show Intros | Plex Support
Generate intro video markers is set as default: as a schedules task or when media is added
Enable intro detection is ticked for that specific library.
I Analysed the library again, but no change.
Is anyone else experiencing this?
Thank you.
Exactly the same problem as decribed here: Skip Intro feature not working on new install
May I paraphrase ?
  1. You have an existing server
  2. When you add media to that server
  3. Intro detection runs
– When –
  1. You have existing media
  2. You setup a new server instance
  3. Intro detection does not run.
If this is correct, are there any logs still in existence which capture this ?
  1. I have an existing server
  2. I add a new library for TV Shows
  3. Intro detection does not run or does not work
I have downloaded the Logs, but there are 72 files taking 78.8 MB. Which are the ones that are needed?
When you ZIP them, they will be about 4-5 MB.
Please include them all (Settings - Server - Troubleshooting - Download Logs)
It will give you a ZIP file
Here they are.
If it helps, around 16:52 I created a new library called ‘Test’ and added Alias S02 for testing purposes. Thank you.
Plex Media Server Logs_2021-12-10_16-53-05.zip (4.4 MB)
@greentrancer
I’ve checked with the team.
Intros are normally detected when -
  1. During normal nightly maintenance if enabled for the section.
  • This includes newly created sections.
  1. Once initial detection has been performed, any new media will be added to the detection queue.
Because intro detection takes a lot of resources on smaller processors (like NAS systems), it’s saved for running during maintenance.
Do you have a case where it’s not running during maintenance ?
I believe so. I have the server running from 2-3 days ago when I did a fresh install, and as far as I am aware, the maintenance occurs every night around 2.
Few weeks ago whilst on the old type library and so on, I remember seeing the intro detection in the dashboard taking place right after I was scanning the library for new items, but it is definitely no longer the case now.
Can I check if the maintanance actually took place overnight in the logs?
Edit: I checked the logs myself today and can see a certain number of things happened last night after 2, but still no Intros for any of the episodes. Here are the logs:
Plex Media Server Logs_2021-12-11_11-41-45.zip (4.6 MB)
@ChuckPa did you get a chance to look over those logs? Anything obvious?
