When the “Skip intro” button shows up and I press OK/Select, it just shows the interface instead of activating the button. I need to press Up three times to give the button focus before I can press OK/Select. I tried it with a BT keyboard and the same thing happens when pressing Enter. I assume it happens the same way with the Logitech Harmony remote because it’s paired as a BT keyboard and the OK/Select button is probably mapped to Enter. So, in short, it would be nice if an Enter keypress (Numpad or otherwise) would trigger the “Skip intro” button while it’s visible.
Server Version#: 1.19.4.2865
Player Version#: 8.1.0.17967
Nvidia Shield TV Android version#: 8.0.2
