I uninstalled version 1.14 and installed version 1.0 and all my issues are solved. I couldn’t get the remote server to connect, TV’s wouldn’t connect, Androids wouldn’t connect. After installing 1.0 every thing is back to normal. I didn’t have to do anything but install 1.0.
I removed your link as per Plex policy.
this method would probably work without you needing to downgrade:
Why is this marked as solved ? What is the solution ?
I am searching for a solution to this problem and nothing works.
Here is a solution that finally worked for me: https://forums.plex.tv/discussion/233514/after-network-reboot-lost-remote-access-and-cant-get-it-back
Hi - i recently upgraded to PMS 1.1.4 and happened to change my server settings to a static IP with manual port forwarding. I had assumed that the port fwd changed had caused my problems in accessing my server remotely but it sounds like it is a bug with the new PMS version?
From the LG tv thread linked to by OttoKerner it sounds like i need to log out of PMS and log back in? It is strange as i can stream media from my server using the iOS app, just not through the web app on a windows PC!
