Some Episodes randomly don't show up
For some reason, in the Boruto series, i have 1 episode (115) that just won’t show up on Plex.
It’s the episode called “Team 25”, it only shows up on plex when i change the name to something else, or clear it completely…
  • “Boruto - 115 - Team 25” = does not show up
  • “Boruto - 115 - Team_25” = does not show up
  • “Boruto - 115 - Team-25” = does not show up
  • “Boruto - 115 - erovkneobvrnm” = shows up
  • "Boruto - 115 - " = shows up
  • “Boruto - 115 - Team 25” = does not show up anymore
The problem with the anime numbering is that the agent will check the number in your file. So 115 and 25 may be set to 25. Write the non-episode number in full letter “Boruto - 115 - Team Twenty-Five”.
That is if you insist on using the Absolute numbering, otherwise just follow the advice posted by Trumpy81.
Thanks for the response, but it isn’t all to helpfull, I’m well-aware of the Plex Naming Scheme.
It was first Split up into Seasons, but it would only name Season 1,
Then renamed everying into Season 1, but still it wouldn’t pick everything up.
Only when i switched to the Japanese numbering (e.g. 1 to 999 instead of SxxExx) did Plex show all the names correctly.
Ismelda, that is very helpfull.
That is some info i did not know about ! Thanks
Now my filename makes sense and plex picks it up :slight_smile:
This is how i deal with anime :
Fairy Tail - S07E03 - ep268 Bluray-1080p.mkv
Combining the season numbering from TheTVdb with the absolute ordering of the episode from Japan.
Shortened to only the episode number because some episodes titles are just too long.
