Some remote access stopped working
Sorry for the delay.
I was getting a late dinner.
Neo server removed.
Your cert reset
You can restart now
@tangpho
Your certificate is reset.
You can restart the server now
All good now! Thank-you so much!!
Looks like I just scored the same issue. Can I get a certificate reset please?
(Also, if I just generate my own validly signed ssl cert and upload it, would that fix this issue?)
Thanks :slight_smile:
Oct 07, 2020 17:43:44.541 [0x7f47cd18d700] ERROR - OCSP: Our certificate (SN: 0637DE027330580024D973F903FE6BDF) has been revoked. Revocation reason: '(UNKNOWN)'. Not refreshing OSCP.
Oct 07, 2020 17:43:44.541 [0x7f47cd18d700] INFO - OSCP: fetching new certificate to replace revoked one.
Oct 07, 2020 17:43:44.541 [0x7f47cd18d700] DEBUG - CERT: Forcing refresh.
Oct 07, 2020 17:43:44.541 [0x7f47cd18d700] DEBUG - HTTP requesting POST https://plex.tv/devices/71487f95f7f22b89ac2c0c6ea96cdeb2073e5cbe/certificate?version=2&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct 07, 2020 17:43:45.608 [0x7f47cd18d700] DEBUG - HTTP 404 response from POST https://plex.tv/devices/71487f95f7f22b89ac2c0c6ea96cdeb2073e5cbe/certificate?version=2&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
@ChuckPa
I recreated the docker image using plexinc/pms-docker:1.20.1.3252-a78fef9a9, but I still have that same problem. I can see my server when I use the custom domain, but I can’t see the server with the android apps or app.plex.tv
Plex Media Server Logs_2020-10-07_10-19-40.zip (2.5 MB)
I found the problem on my system.
I’m using portainer, and inside the plex container I had to add an ENV variable called ā€œADVERTISE_IPā€, with the values being ā€œmydomain:443, mydomain:80ā€
Maybe someone more savvy than me can explain how to do this without portainer.
Hope this helps anyone else who still struggles after the cert error.
Same problem here:
Plex Media Server Logs_2020-10-07_13-36-52.zip (486.7 KB)
Hey sorry I had called it a night before I saw your response and after restarting this morning I am still getting the cert 404. What are the next steps? thanks!
Hello, same problem for me.
PMS on my NAS.
Thanks for your help.Plex Media Server Logs_2020-10-07_15-33-04.zip (2.9 MB)
@Hutch8729
Shut it down.
we let it sit for 10-15 min
Then I reset
Then you start it
(PMS itself realizes it needs a new cert)
Ok I have shut down my PMS. Start the timer.
Same issue here with remote access. attached is my log file. Thank youPlex Media Server (2).zip (47.8 KB)
@Hutch8729
Restart the server
Looks to be working. Thanks!!
@ChuckPa
Would you mind checking my logs posted earler?
I’m not sure if I just got lost in the forest or if support is different/limited for non-Plex Pass users, but if that’s the case just let me know and I’ll sub up. I believe it’s the same and I cannot find a solution on my own so far.
@andreasmaks
Turn DEBUG logging back on then SAVE (Keep verbose OFF)
Now restart and gather fresh logs.
You are hurting yourself and making it impossible for us to help.
Lowering level does not save space. They are fixed size (10.4 MB)
@mogball
You can start now.
I’m also having a 404, logs are attached. The server is now shut down. Thank you!
Plex Media Server.zip (17.9 KB)
Email attachments do not work in the forum.
Please use drag & drop
Noticed that something didn’t work, I edited the previous post. Is this okay?
