Some remote access stopped working
Plex Media Server Logs_2020-10-05_13-07-44.zip (3.1 MB)
I am unsure where to check that.
Sorry novice here.
Hi @ChuckPa I posted further up in the thread can you please help me.
Same here, no remote access for 2 days.
Plex Media Server Logs_2020-10-05_19-06-02.zip (3.5 MB)
@Abheeshek_Sharma
This is what we look for in the ZIP file (Plex Media Server.log)
Oct 05, 2020 13:07:12.371 [7484] DEBUG - HTTP requesting POST https://plex.tv/devices/48e7cd7f6cf33ef44102a90f4758c4a7614edb85/certificate?version=2&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct 05, 2020 13:07:12.988 [7484] DEBUG - HTTP 404 response from POST https://plex.tv/devices/48e7cd7f6cf33ef44102a90f4758c4a7614edb85/certificate?version=2&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct 05, 2020 13:07:12.988 [7484] ERROR - CERT: Could not fetch certificate from the cloud: 404
Oct 05, 2020 13:07:12.998 [4604] DEBUG - HTTP 200 response from GET https://plex.tv/media/providers?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct 05, 2020 13:07:12.999 [7484] DEBUG - HTTP requesting GET https://plex.tv/media/providers?X-Plex-Token=xxxxxxxxxx
I just reset the certificate.
You may now restart the server
@BubbiBjQrn
Thanks, Got it. Certificate reset.
Restart PMS
I am have the same issues as everyone else. Can you take a look at my logs?
Oct 05, 2020 20:00:17.006 [0x7fcb28ff9700] ERROR - CERT: Could not fetch certificate from the cloud: 404
Plex Media Server Logs_2020-10-05_20-11-23.zip (2.3 MB)
@kevingoffe_yahoo.co.uk
  1. You had a whole bunch of dead servers in there from many years ago – REMOVED
  2. Certificate reset
  3. You may now restart
@STRUBartacus
Certificate reset
Restart the server
All fixed.
Many thanks for the quick response.
@ChuckPa thanks for your help it seems to be working now.
This looks like it fixed the problem.
However I am not able to sign in remotely into my server via Google Chrome. Using my external IP, XX.XXX.XXX.X:32400 and http://app.plex.tv/desktop?secure=0 and it just spins, all i see if that it is waiting for assets.plex.tv.
Plex Media Server Logs_2020-10-05_13-19-43.zip (3.0 MB)
It worked! Thanks a lot!
@ChuckPa
They became mad with my log ?! :slight_smile:
@Abheeshek_Sharma
You just stepped beyond my knowledge of Windows.
Please create a fresh thread and ask the Ninjas to help.
I am a linux system engineer. I do two thing with windows – wash or break them :slight_smile:
Hi @ChuckPa,
I am having the same issue with remote access. Could you please see logs and help me if possible.
Plex Media Server Logs_2020-10-05_21-54-09.zip (71.7 KB)
@Yuretc
Your server has a certificate but unable to publish.
I have reset the certificate anyway.
Please restart as soon as possible.
I believe I’m having similar issues. Lost secure connections sometime Saturday. I did some digging around and tried some suggestions but the best I could do is get it to work with insecure connections. Even in the insecure state though I could not get my PMS to enable remote access and I had the same log line as some others showing it switching to ā€œMapped - Not Publishedā€. During that time my android client debug logs show the server as unreachable.
Currently the server is offline after gathering the logs but could you take a look?
@ChuckPa
I’m also having the same issue with remote access.
Coud you please reset the certificate?
Plex Media Server Logs_2020-10-05_22-39-39.zip (1,6 MB)
@Exlence
You have several servers listed. I spot the obvious older ones
It appears Crossfiles is the only active one. Is this correct?
If so, would you like me to remove the others while here?
