Server Version#1.22.1.4228-724c56e62
For some time now, my Plex running on Nvidia Shield 2017 is causing me a lot of problems.
It hangs, sometimes doesn’t respond. I factory reset the Nvidia Shield and reinstalled Plex a lot of times.
Trying to find the cause (and a solution) I noticed in my log that something is triggering errors every X seconds.
SSDP: Error parsing device schema for http://192.168.1.14:49153/description0.xml
SSDP: Error parsing device schema for http://192.168.1.14:49153/description3.xml
And
Those IP doesn’t even belong to the Shield. Maybe it’s my Sky Topbox, I’m not sure.
Anyway, what is that and should I worry?
