Hi
I’ve been trying and trying again and again to make that work, but I just can’t and that just drives me nuts…
- Plex server, up to date, runs on my Synology DS214Play
- Plex client runs, up to date, on my Samsung TV
I have movies in different format, always with .srt subtitles as english is not my mother tongue but I just hate watching dubbed movies and my english understanding and earing is good enough forme to watch movies/tv. I need the subs, in english, every now and then when the ambiance gets messy, lower etc etc etc…
So, many of my movies have subs detected. But some, for some reason, refuse to show up…
The agents are correctly set (works for other movies):
Naming is correct (works for other movies)
Another movie, same format shows correctly (even though, for some weird reason, it says “unknown” for the subs):
But this movie (and others) does not…
They don’t show on my tv, on the web client, nowhere. On my computer I can select the srt file when watching with vlc or Microsoft Movie, and they work…
So I went further, and compared the files themselves…
Non working:
Working:
So file magic numbers do match, header and trailer
So let’s compare encoding:
Non working:
Working:
Yes I did refresh the movie:
And it doesn’t change anything. Yesterday I refreshed my whole library, doesn’t change anything either. So, I’m a bit out of ideas… How do I manually set the subtitles? Any way to add them to the DB? The DB is surely something like sqlite or a simple xml struts?
I know I can use an agant to download the subs, but it tends to download subs that aren’t in sync, sometimes with over 20 seconds and for some weird reason, you can only adjust 10 seconds in plex, not more (WTF, WHY???)
Can anyone help further?
Square brackets are always used by engine to add informations you don’t want the crawlers to replace. XBMC was using everything between square brackets, explaining why I kept that habit. Thanks to your poiting I will change that habit then. But that’s another topic, let’s not open a debate for that.
