SSL Certificate Errors
Your WD is fine:
Valid	Wed, 03 Nov 2021 07:07:04 +0000	Wed, 03 Nov 2021 07:07:40 +0000
Your Mac hasn’t connected in a month and had an old certificate which I reset.
Valid	Fri, 06 Aug 2021 02:28:19 +0000	Fri, 06 Aug 2021 02:28:31 +0000
@ChuckPa Thanks for the assistance, but I’m still having trouble connecting to my content from and AndroidTV. is there a way for me to send you my log?
@nguyendk
Did you read the above announcement ?
Based on what I’ve seen, I wonder if your TV falls into that category?
If so, you’ll need to configure PMS to run without authentication on your home LAN.
It’s not difficult to do.
okay thanks, i’ll give this a shot!
To do the “without Auth” for your home LAN.
  1. Settings - Server - Network - Show Advanced,
  2. In the box for “hosts allowed without authentication”
  3. IP address,IPaddress (NO SPACES else it will fail)
    -or-
  4. LAN subnet - e.g. 192.168.0.0.24 (also NO SPACES - leading or trailing)
From the TV app I set it to allow insecure connection (set to always). This seems to have worked! thanks!
Hi ChuckPa, can you also check my server. Can no longer connect from the Plex app externally.
CERT: incomplete TLS handshake from X.X.X.X:62288: sslv3 alert certificate unknown
I have a certificate from ZeroSSL on my PMS.
@Keyn28
Your cert is new
Valid	Wed, 03 Nov 2021 17:28:49 +0000	Wed, 03 Nov 2021 17:28:59 +0000
That said, are the remotes with difficulties any of those listed above in the announcement ?
Hey mate Ive got the same issue trying to use rasplex to connect remotely.
CERT: incomplete TLS handshake from [::ffff:58.6.248.21]:51962: sslv3 alert certificate expired
I have secure connections set to preferred on the server and also allowed
List of IP addresses and networks that are allowed without auth
58.6.248.21
Is there anything else I can do to allow it to connect. Its running latest version rasplex.
@Jgrov2
Rasplex machines root certificate expired.
On Github, the author generated new binaries with that root certificate updated.
The solution for Rasplex players is to update the installed software
Your server has a valid certificate. Have you restarted it recently?
	Valid	Sun, 31 Oct 2021 11:27:44 +0000	Sun, 31 Oct 2021 11:27:57 +0000
Yes, it is 3 LG C9 with WebOS 4.9.
That’s why I set up a certificate from ZeroSSL on the PMS. On a remote I was able to fix the problem by blocking access to *.plex.direct.
Thanks.
That is one way to fix it ( by getting a bigger hammer! :slight_smile: Good thinking )
I have the cert error aswell. Followed a work around to add ips which Do Not need to authenticate since than i can See the library but cant play anything.
@hypePG
If you’ve resolved the issues with the certificate for those players,
but are still having playback issues in general, Please create a fresh thread , appropriately titled, and ping me .
Thanks.
Hi. I seem to have this problem too. Cant connect to my plex server from my Shield or my phone. CERT: incomplete TLS handshake: sslv3 alert certificate unknown
Plex console shows this message. What to do?
@jaba89
Your certificate is current (not pre-Sept 30 nor expired)
Valid Fri, 08 Oct 2021 21:58:03 +0000 Fri, 08 Oct 2021 21:58:38 +0000
May I see your debug logs which show the cert message?
@jaba89
I don’t know BSD. What I do see is that Plex is trying to download the certificate but I don’t see where it’s being acknowledged and then used.
It’s showing where it doesn’t have anything cached – which it should.
If it can’t save the certificate then that speaks to ownership / permission for the files.
Looking at the start.sh script, I can’t tell where PMS resides or which username it runs as.
Would you be able to look that up (investigate how it is on your system),
Next make certain:
  1. All your metadata directories have permission 755
  2. All your metadata files have permission 644
  3. All files are owned by the username Plex runs as.
  4. Restart Plex
HI Can you please reset my certificate as well, getting the following message:
CERT: incomplete TLS handshake fr om [::ffff:10.0.0.4]:62422: sslv3 alert certificate expired
@BenG-1989
You had an old and a new certificate attached to your server. I reset it.
Please restart the server
I have restarted server and still getting the same message:
DEBUG - CERT: incomplete TLS handshake from [::ffff:10.0.0.4]:33825: sslv3 alert certificate expired
