SSL Certificate Errors
@EsSharing
I just looked at your account. The number of certificate requests is not normal.
https://acme-v02.api.letsencrypt.org/acme/order/XXXX/25536962670	Valid	Sun, 19 Sep 2021 03:30:27 +0000	Sun, 19 Sep 2021 03:30:38 +0000
https://acme-v02.api.letsencrypt.org/acme/order/XXXX/40538674870	Valid	Thu, 18 Nov 2021 04:30:25 +0000	Thu, 18 Nov 2021 04:30:34 +0000
https://acme-v02.api.letsencrypt.org/acme/order/XXXX/44886836060	Valid	Sun, 05 Dec 2021 09:11:28 +0000	Sun, 05 Dec 2021 09:11:41 +0000
https://acme-v02.api.letsencrypt.org/acme/order/XXXX/44910074350	Valid	Sun, 05 Dec 2021 11:25:22 +0000	Sun, 05 Dec 2021 11:25:34 +0000
https://acme-v02.api.letsencrypt.org/acme/order/XXXX/44916646990	Valid	Sun, 05 Dec 2021 12:03:52 +0000	Sun, 05 Dec 2021 12:04:01 +0000
This is telling me that your PMS is not able to save the certificate after downloading.
The most likely candidates for issues are:
  1. UID / GID of the directories and files not matching the PLEX_UID/PLEX_GID -or- PUID/PGID of the container
-and/or-
  1. Permissions of the /config/Library/Application Support/Plex Media Server/Cache directory do not allow the certificate to be updated.
Your DEBUG log files, collected after restarting Plex, should show if this is a permissions problem.
Same issue on Plex (linux). Thread: Not secure available since server move (https://forums.plex.tv/t/ssl-certificate-errors/726486/900)
Thank you!
Thomas
@Nostromo81
Your server certificate is fine.
	Valid	Mon, 11 Oct 2021 19:14:42 +0000	Mon, 11 Oct 2021 19:14:53 +0000
What is the problem you’re experiencing?
Is it a problem with a Television?
Several TV have a certificate error, also when I am accessing from outside via Browser i have the a untrusted connection - or it is not showing my libraries.
It all started after migrating the server from an old Ubuntu laptop to a Hyper-V Ubuntu.
I always see an error about TLS in the Logs.
CERT: incomplete TLS handshake from 165.225.200.213:5183: sslv3 alert certificate unknown
@Nostromo81
Do any of the devices fall into this list? (This is not an exhaustive list)
Hello, I appear to be having a similar “certificate unknown” error when trying to connect to my server from Android phones (Samsung and Roku TV’s connect fine).
Here are my logs, please let me know if you there’s anything else you need from me.
Plex Media Server Logs_2021-12-10_12-02-34.zip (4.5 MB)
@scottmoore
Is this a TV or a phone?
Dec 10, 2021 10:51:29.666 [15412] DEBUG - [Now] User is scottmoore (ID: 1)
Dec 10, 2021 10:51:29.666 [15412] DEBUG - [Now] Device is Android (Android).
Dec 10, 2021 10:51:29.667 [15412] DEBUG - [Now] Profile is Android
Dec 10, 2021 10:51:29.667 [15412] DEBUG - [Now] Updated play state for /library/metadata/219375.
Dec 10, 2021 10:51:29.667 [15412] DEBUG - Statistics: (6e450e97-85a1-4bec-af85-72acd6bcd12b) Reporting active playback in state 0 of type 10 (scrobble: 0) for account 1
Dec 10, 2021 10:51:29.669 [16792] DEBUG - Completed: [208.98.223.30:34782] 200 GET /:/timeline?state=playing&duration=282618&time=200&playQueueItemID=218562&key=%2Flibrary%2Fmetadata%2F219375&ratingKey=219375&playQueueID=5635&playQueueVersion=1&containerKey=%2FplayQueues%2F5635&hasMDE=1&includeFields=thumbBlurHash (28 live) TLS GZIP 6ms 374 bytes (pipelined: 13)
This is a phone.
I’m not seeing any certificate errors there.
What are you seeing and where please ? Screenshot possible ?
From my android app I get the message that my server is offline.
This isn’t accurate though as I am concurrently logged into the server on my laptop and watching the console as that connection is attempted. This is where I see the certificate error:
I am happy to send anything else that helps, just let me know.
Restart your phone and try it again.
I have learned they updated the backend. TLS 1.2 → TLS 1.3 seems to be what happened (although not entirely clear)
I suspect the phone needs to renegotiate
If that gives no relief, Please download your logs again after that attempt and will go :hammer: on :door: :smiling_imp:
Unfortunately still the same result - server appears offline on android app.
Incidentally, the Windows app is able to connect and display my libraries, however I get the following error message when attempting playback.
An unknown error occurred (4294967283)
Error code: 4294967283
Here are the logs after that attempt as well.
Plex Media Server Logs_2021-12-10_13-46-40.zip (4.6 MB)
I just used my web browser to go direct to the IP Plex.tv has for your server.
It responded.
This is a phone app problem.
Which is your preference ?
  • Reset the customizations and choose the server again ?
  • Reinstall the app and choose the server then set customizations ?
Yes, that has also been what’s puzzled me as I too have been successful going directly to plex.tv and playing from there - from the same machine that the Windows app does not work from.
I have actually already reinstalled the app on my phone as well before contacting you. Don’t mind trying again, but I wouldn’t expect it to help at this point (unless anything has changed on your side?).
Also, fwiw, my wife’s phone (also Android) is not able to connect to the server either so definitely not just isolated to my phone.
While this isn’t funny… I’m glad I don’t use Android :smiling_imp:
I will go ask a few more folks about how to dig deeper on this.
Much appreciated, thank you!
@ChuckPa no problem of permission, I myself deleted the p12 to force its renewal
the tls 1.3 goes without worries locally, but not remotely via the domain (tls negotiation failure in the iphone logs)
Yes. Good to know for the older TV-set.
Now also the up2date browser from outside are working… I noticed a wrong timezone on the Ubuntu server… and some 10 min time/shif…
Thx
Thomas
@EsSharing
I’m following what’s happening on the backend changes.
I’m also not getting a clear understanding.
I know what they did (abstract) but no details with which to help here.
I am still trying to resolve.
If you allow settings as “Preferred”, does it connect ok remotely?
probs solved :stuck_out_tongue:
