What does
mean ?
PEBKAC ?
AGAIN?
“Preferred” means it will fall back to HTTP (not desired) but is a stop-gap measure until this whole thing is sorted out.
What does
mean ?
PEBKAC ?
AGAIN?
I had the TLS profile level in “modern” before my fresh installation, but that was only a residual bug of dsm migrations, by going back to “intermediate”, everything is back to normal.
Thank you for sharing.
I’ll figure out what they mean by “modern” TLS profile
modern = tls 1.3
intermediate = tls 1.2 & 1.3
HI mate, can you reset mine please I’ve just migrated server and getting SSL errors and rate limiting messages in my log!
You have an ownership/permissions problem in the Plex Media Server directory.
It’s made too many certificate requests. This only happens when something has gone into /var/lib/plexmediaserver .
Do you have any scripts or programs which write to this area?
If so, you need to stop them and make changes.
Can you tell me what’s happened?
Are you using SNAP or DPKG ?
The daily quota has been exceeded. This is why it’s being throttled.
Valid Sun, 12 Dec 2021 19:21:59 +0000 Sun, 12 Dec 2021 19:34:45 +0000
Valid Sun, 12 Dec 2021 19:50:07 +0000 Sun, 12 Dec 2021 20:06:16 +0000
Valid Sun, 12 Dec 2021 20:26:34 +0000 Sun, 12 Dec 2021 20:47:25 +0000
Valid Sun, 12 Dec 2021 21:11:30 +0000 Sun, 12 Dec 2021 21:36:11 +0000
Valid Sun, 12 Dec 2021 22:04:28 +0000 Sun, 12 Dec 2021 22:33:29 +0000
Seems like the same issue impacts new docker setup / install.
Dec 12, 2021 19:09:39.026 [0x7fb09650fb38] DEBUG - CERT: Forcing refresh.
Dec 12, 2021 19:09:39.028 [0x7fb09650fb38] DEBUG - CERT: Certificate did not exist, fetching a new one.
Dec 12, 2021 19:09:39.029 [0x7fb09650fb38] DEBUG - HTTP requesting GET https://plex.tv/api/v2/devices/51cb8b3e90c781610943d28fb8deb039d596a350/certificate/subject
Dec 12, 2021 19:09:39.420 [0x7fb09650fb38] DEBUG - HTTP/2.0 (0.4s) 200 response from GET https://plex.tv/api/v2/devices/51cb8b3e90c781610943d28fb8deb039d596a350/certificate/subject
Dec 12, 2021 19:09:39.508 [0x7fb09650fb38] DEBUG - HTTP requesting PUT https://plex.tv/api/v2/devices/51cb8b3e90c781610943d28fb8deb039d596a350/certificate/csr?reason=missing&invalidIn=0
Dec 12, 2021 19:09:39.621 [0x7fb09650fb38] DEBUG - HTTP/2.0 (0.1s) 429 response from PUT https://plex.tv/api/v2/devices/51cb8b3e90c781610943d28fb8deb039d596a350/certificate/csr?reason=missing&invalidIn=0 (reused)
Dec 12, 2021 19:09:39.621 [0x7fb09650fb38] ERROR - CERT: Error acquiring new certificate: Failed to upload CSR: 429, <?xml version="1.0" encoding="UTF-8"?>
<errors>
<error code="1003" message="API rate limit exceeded"/>
</errors>
I’ve had a similar issue for a while. I can access everything remotely on iOS and my Fire TV but app.plex.tv cannot connect to my server. When I try to manage my server from from that site I get a “Unable to connect to ‘server’ securely.” message.
This is what the logs show me when I retry the connection.
Dec 12, 2021 17:36:13.532 [0x7fafed579b38] Debug — CERT: incomplete TLS handshake from [::ffff:192.168.0.176]:40218: sslv3 alert certificate expired
Dec 12, 2021 17:36:13.679 [0x7fafed556b38] Debug — CERT: incomplete TLS handshake from [::ffff:192.168.0.176]:40230: sslv3 alert certificate expired
Dec 12, 2021 17:36:15.295 [0x7fafed579b38] Debug — CERT: incomplete TLS handshake from [::ffff:192.168.0.176]:40242: sslv3 alert certificate expired
Dec 12, 2021 17:36:17.394 [0x7fafed556b38] Debug — Completed: [127.0.0.1:44702] 200 GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (9 live) GZIP 20001ms 5 bytes (pipelined: 1)
Dec 12, 2021 17:36:17.400 [0x7fafed24ab38] Debug — Request: [127.0.0.1:44740 (Loopback)] GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (9 live) GZIP Signed-in Token (USER)
Dec 12, 2021 17:36:17.400 [0x7fafed24ab38] Debug — Content-Length is -1 (of total: -1).
Dec 12, 2021 17:36:25.491 [0x7fafeaea3b38] Debug — CERT: Version mismatch, fetching a new one.
Dec 12, 2021 17:36:25.493 [0x7fafeaea3b38] Debug — CERT: Certificate expires soon, fetching a new one.
Dec 12, 2021 17:36:25.493 [0x7fafeaea3b38] Debug — HTTP requesting GET https://plex.tv/api/v2/devices/3289351cc7c0d5d1d36c4aca612cc61c01e9db31/certificate/subject
Dec 12, 2021 17:36:25.990 [0x7fafeaea3b38] Debug — HTTP/2.0 (0.5s) 200 response from GET https://plex.tv/api/v2/devices/3289351cc7c0d5d1d36c4aca612cc61c01e9db31/certificate/subject
Dec 12, 2021 17:36:26.119 [0x7fafeaea3b38] Debug — HTTP requesting PUT https://plex.tv/api/v2/devices/3289351cc7c0d5d1d36c4aca612cc61c01e9db31/certificate/csr?reason=expiring&invalidIn=-25792585
Dec 12, 2021 17:36:26.266 [0x7fafeaea3b38] Debug — HTTP/2.0 (0.1s) 429 response from PUT https://plex.tv/api/v2/devices/3289351cc7c0d5d1d36c4aca612cc61c01e9db31/certificate/csr?reason=expiring&invalidIn=-25792585 (reused)
Dec 12, 2021 17:36:26.266 [0x7fafeaea3b38] Error — CERT: Error acquiring new certificate: Failed to upload CSR: 429, <?xml version="1.0" encoding="UTF-8"?>
<errors>
</errors>
Any chance to get my cert throttle reset also?
May I have your logs please?
Plex.tv is not showing you as throttled.
Dec 12, 2021 17:22:18.792 [0x80724b700] DEBUG - [EventSourceClient/pubsub] PublicAddressManager: Obtaining public address and mapping port.
Dec 12, 2021 17:22:18.792 [0x80724b700] DEBUG - [EventSourceClient/pubsub] MyPlex: async reachability check - current mapped state: 'Not Mapped'.
Dec 12, 2021 17:22:18.792 [0x80724b700] WARN - [EventSourceClient/pubsub] MyPlex: attempted a reachability check but we're not yet mapped.
Dec 12, 2021 17:22:18.792 [0x80724b700] DEBUG - [EventSourceClient/pubsub] Successfully connected to 184.105.148.117.
Dec 12, 2021 17:22:18.824 [0x807bb2700] DEBUG - HTTP/2.0 (0.2s) 429 response from PUT https://plex.tv/api/v2/devices/4596368ef0140f0b27e8633871bcf512dd76d5dc/certificate/csr?reason=missing&invalidIn=0 (reused)
Dec 12, 2021 17:22:18.824 [0x807bb2700] ERROR - CERT: Error acquiring new certificate: Failed to upload CSR: 429, <?xml version="1.0" encoding="UTF-8"?>
<errors>
</errors>
Dec 12, 2021 17:22:18.824 [0x808930a00] DEBUG - MyPlex: sendMapping resetting state - previous mapping state: 'Not Mapped'.
Dec 12, 2021 17:22:18.824 [0x808930a00] DEBUG - MyPlex: mapping state set to 'Unknown'.
I’ve attached my logs.
Plex Media Server.log.zip (381.7 KB)
Hi, I’m also having issues with certificate api limits. Can you reset it?
Here is the message being shown repeatedly in my logs
Dec 12, 2021 22:09:09.983 [10408] ERROR - CERT: Error acquiring new certificate: Failed to upload CSR: 429, <?xml version="1.0" encoding="UTF-8"?>
<errors>
</errors>
From what I can see at Plex.tv, you’ve created 4 different variations of your server within the past few hours?
uhh yeah but this is the last one I swear, part of the creating multiple was having this issue over and over again and thinking, maybe if I just reinstall this will fix it.
Your account is locked so hard that I can’t reset it.
I’ve asked the team to help but , at this point, you will need wait until morning (London time)
ok, is there a time period that it will unlock it’s self at?
I recently migrated to a new server and I am getting the same error in the logs. @ChuckPa can you help?
The best thing to do is stop the server.
By stopping it, it doesn’t keep hammering.
This allows Plex.tv to think the server will behave and it will then naturally unlock.
You might be able to get it back in a couple hours that way
What’s bothering me is why this is occurring.
“Big Hammer” approach is never wise
