Stations missing
Hi!
Please have a look at the following image:
Plex works with my Fritz!Box 6600 Cable for receiving stations. But some stations are missing. As you can see, channel numbers in Plex start with 11. But stations like “ORF 1 HD” are below 11. So they don’t appear in the list.
Those stations also aren’t above 11 (without numbers). How can I detect/add those stations?
Server Version#: 1.26.1.5772
Player Version#: Latest web
Tuner Make/Model: AVM Fritz!Box 6600 Cable
Guide/Lineup name:
Using XMLTV?: no
Channel number/Name:
I had to modify the Kabelsignal transponder file located in:
/volume1/@appstore/PlexMediaServer/Resources/Tuner/Shared/scanners/dvbc/transponder
to include the according transponders. Afterwards, the stations were found just fine. Path must be altered to platform, I’m on Synology.
I’ll upload my modified ini, it corresponds with the stations list as of mai 2022.
5236.ini.zip (1.2 KB)
Hi, I am also on Synology, but I don’t have this Path. Can you point me in the right direction?
Thanks.
Maybe you’re not on /volume1 (but volume2, 3, whatever). The following path should be fine. Try not to enter the whole path at once but type one letter and press TAB.
