I am having issues with remote access. It continually connects/disconnects randomly. I have opened the port on my ASUS router but still having issues. I do have a Centurylink Actiontec Modem/Router combo in front of my ASUS router that I believe is causing the issue but not entirely sure. Any help or guidance is greatly appreciated. Thanks!
Two routers can commonly cause a “double-NAT” situation. You can find an explanation, and steps to take, here:
I did see that guide and looked to see if I had a double nat issue and I do not, both IPs match.
Well, that’s about the extent of my skills with this type of problem. Hopefully someone else will jump in.
hey thanks for trying though.
Hi, since yesterdays update I am having the same problem again, the last time I set up port forwarding on my router and all was well till the update, I have spent the last 2 days re-configuring and still no joy, what is strange is that if I do get it to stay green and then click onto another setting in the list it goes off again, but if I stay on the page it stays green, but even then no one can stream not even me on another tv in another room. I need help and a fix for this as soon as please. by the way window 10 64bit, and a BT Smart Hub 2
