Stuck on "Accessing Trailers" after connecting new router
  • Your ATV model (2 or 3) and firmware version (found under the ATV settings > general > about > Apple TV software):
    Apple TV 3 / v7.0
  • The DNS server set on the ATV (found under the ATV settings > general > network > DNS)
    192.168.0.102
  • The local IP address of the device that PlexConnect is installed on:
    192.168.0.111
  • The device and operating system (including version number) that PlexConnect is installed on:
     iMac / OSX 10.8.5
  • The device and operating system (including version number) that the Plex media server (PMS) is installed on:
     iMac / OSX 10.8.5
  • The Plex media server (PMS) version number you are running (do not put 'latest'):
    Version 0.9.11.1.678-c48ffd2
  • The local IP address of the device that the Plex media server (PMS) is installed on:
    192.168.0.111
  • The PlexConnect version number. If using Github source then a time and date of download (look at the creation date of the folder) and if you are using any non-standard setup e.g. Plexify or a fork.
    __VERSION__ = '0.3.1+'
  • The contents of your 'Settings.cfg' file (this is created at first clean shutdown of PlexConnect, using CTR+c)
    [PlexConnect]
    enable_plexgdm = True
    ip_pms = 192.168.178.10
    port_pms = 32400
    enable_dnsserver = True
    port_dnsserver = 53
    ip_dnsmaster = 10.0.1.50
    prevent_atv_update = True
    enable_plexconnect_autodetect = True
    ip_plexconnect = 0.0.0.0
    hosttointercept = trailers.apple.com
    port_webserver = 80
    enable_webserver_ssl = True
    port_ssl = 443
    certfile = ./assets/certificates/trailers.pem
    loglevel = Normal
    logpath = .
  • detailed description of the issue (the clearer you can make this the better):
I've been using the PlexConnect hack on AppleTv 3 for over a year. No issues. Love it and appreciate the hard work on this. I just bought a new router Tp-Link Archer 8. My wifi is now much faster :)
However, PlexConnect no longer works. I run Plexconnect via Terminal. I set the DNS of the ATV3 to match the ip of the imac running PlexConnect, when I select trailers, I get stuck on Accessing Trailers... then it times out. There may be a setting on the router that is interfering but I have no idea how to troubleshoot as I don't know networking very well.
I CAN access Plex Media server via other devices via web browser so I know PMS is working. THANK YOU!
Below is the content of the latest attempt via Terminal.
  • Ensure you post your 'PlexConnect.log' file to pastebin and post the link ('PlexConnect.log' is located in your PlexConnect folder). If possible, follow these steps to create a "more detailed fresh" one
    http://pastebin.com/APf81CHh
Last login: Sun Nov  9 20:56:15 on console
Monolith-2:~ jasonjustice$ cd /Users/jasonjustice/Desktop/PlexConnect-master
Monolith-2:PlexConnect-master jasonjustice$ sudo ./PlexConnect.py
Password:
21:54:04 PlexConnect: ***
21:54:04 PlexConnect: PlexConnect
21:54:04 PlexConnect: Press CTRL-C to shut down.
21:54:04 PlexConnect: started: 21:54:04
21:54:04 PlexConnect: Version: 0.3.1+
21:54:04 PlexConnect: Python: 2.7.2 (default, Oct 11 2012, 20:14:37)
[GCC 4.2.1 Compatible Apple Clang 4.0 (tags/Apple/clang-418.0.60)]
21:54:04 PlexConnect: Host OS: darwin
21:54:04 PlexConnect: IP_self: 192.168.0.111
21:54:04 DNSServer: started: 21:54:04
21:54:04 DNSServer: ***
21:54:04 DNSServer: DNSServer: Serving DNS on 192.168.0.111 port 53.
21:54:04 DNSServer: intercept: ['trailers.apple.com'] => 192.168.0.111
21:54:04 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
21:54:04 DNSServer: forward other to higher level DNS: 10.0.1.50
21:54:04 WebServer: started: 21:54:04
21:54:04 WebServer: ***
21:54:04 WebServer: WebServer: Serving HTTP on 192.168.0.111 port 80.
21:54:04 WebServer: WebServer: Serving HTTPS on 192.168.0.111 port 443.
21:55:50 DNSServer: DNS request received!
21:55:50 DNSServer: Source: ('192.168.0.102', 51396)
21:55:50 DNSServer: Domain: init-p01st.push.apple.com
21:55:50 DNSServer: ***forward request
21:55:55 DNSServer: DNS request received!
21:55:55 DNSServer: Source: ('192.168.0.102', 64118)
21:55:55 DNSServer: Domain: init.itunes.apple.com
21:55:55 DNSServer: ***forward request
21:56:00 DNSServer: DNS request received!
21:56:00 DNSServer: Source: ('192.168.0.102', 51396)
21:56:00 DNSServer: Domain: init-p01st.push.apple.com
21:56:00 DNSServer: ***forward request
21:56:05 DNSServer: DNS request received!
21:56:05 DNSServer: Source: ('192.168.0.102', 64118)
21:56:05 DNSServer: Domain: init.itunes.apple.com
21:56:05 DNSServer: ***forward request
21:56:10 DNSServer: DNS request received!
21:56:10 DNSServer: Source: ('192.168.0.102', 58338)
21:56:10 DNSServer: Domain: local
21:56:10 DNSServer: ***forward request
21:56:15 DNSServer: DNS request received!
21:56:15 DNSServer: Source: ('192.168.0.102', 51396)
21:56:15 DNSServer: Domain: init-p01st.push.apple.com
21:56:15 DNSServer: ***forward request
21:56:20 DNSServer: DNS request received!
21:56:20 DNSServer: Source: ('192.168.0.102', 64118)
21:56:20 DNSServer: Domain: init.itunes.apple.com
21:56:20 DNSServer: ***forward request
21:56:25 DNSServer: DNS request received!
21:56:25 DNSServer: Source: ('192.168.0.102', 58338)
21:56:25 DNSServer: Domain: local
21:56:25 DNSServer: ***forward request
21:56:30 DNSServer: DNS request received!
21:56:30 DNSServer: Source: ('192.168.0.102', 51396)
21:56:30 DNSServer: Domain: init-p01st.push.apple.com
21:56:30 DNSServer: ***forward request
21:56:35 DNSServer: DNS request received!
21:56:35 DNSServer: Source: ('192.168.0.102', 64118)
21:56:35 DNSServer: Domain: init.itunes.apple.com
21:56:35 DNSServer: ***forward request
21:56:40 DNSServer: DNS request received!
21:56:40 DNSServer: Source: ('192.168.0.102', 58338)
21:56:40 DNSServer: Domain: local
21:56:40 DNSServer: ***forward request
21:56:45 DNSServer: DNS request received!
21:56:45 DNSServer: Source: ('192.168.0.102', 51396)
21:56:45 DNSServer: Domain: init-p01st.push.apple.com
21:56:45 DNSServer: ***forward request
21:56:50 DNSServer: DNS request received!
21:56:50 DNSServer: Source: ('192.168.0.102', 64118)
21:56:50 DNSServer: Domain: init.itunes.apple.com
21:56:50 DNSServer: ***forward request
21:56:55 DNSServer: DNS request received!
21:56:55 DNSServer: Source: ('192.168.0.102', 53157)
21:56:55 DNSServer: Domain: time.apple.com
21:56:55 DNSServer: ***forward request
21:57:00 DNSServer: DNS request received!
21:57:00 DNSServer: Source: ('192.168.0.102', 53157)
21:57:00 DNSServer: Domain: time.apple.com
21:57:00 DNSServer: ***forward request
21:57:05 DNSServer: DNS request received!
21:57:05 DNSServer: Source: ('192.168.0.102', 58171)
21:57:05 DNSServer: Domain: local
21:57:05 DNSServer: ***forward request
21:57:20 DNSServer: DNS request received!
21:57:20 DNSServer: Source: ('192.168.0.102', 53249)
21:57:20 DNSServer: Domain: apple.com
21:57:20 DNSServer: ***forward request
21:57:25 DNSServer: DNS request received!
21:57:25 DNSServer: Source: ('192.168.0.102', 63800)
21:57:25 DNSServer: Domain: local
21:57:25 DNSServer: ***forward request
21:57:30 DNSServer: DNS request received!
21:57:30 DNSServer: Source: ('192.168.0.102', 58217)
21:57:30 DNSServer: Domain: www.apple.com
21:57:30 DNSServer: ***forward request
21:57:35 DNSServer: DNS request received!
21:57:35 DNSServer: Source: ('192.168.0.102', 58807)
21:57:35 DNSServer: Domain: iadsdk.apple.com
21:57:35 DNSServer: ***forward request
21:57:40 DNSServer: DNS request received!
21:57:40 DNSServer: Source: ('192.168.0.102', 53249)
21:57:40 DNSServer: Domain: apple.com
21:57:40 DNSServer: ***forward request
21:57:45 DNSServer: DNS request received!
21:57:45 DNSServer: Source: ('192.168.0.102', 63800)
21:57:45 DNSServer: Domain: local
21:57:45 DNSServer: ***forward request
21:57:50 DNSServer: DNS request received!
21:57:50 DNSServer: Source: ('192.168.0.102', 58217)
21:57:50 DNSServer: Domain: www.apple.com
21:57:50 DNSServer: ***forward request
21:57:55 DNSServer: DNS request received!
21:57:55 DNSServer: Source: ('192.168.0.102', 58807)
21:57:55 DNSServer: Domain: iadsdk.apple.com
21:57:55 DNSServer: ***forward request
21:58:00 DNSServer: DNS request received!
21:58:00 DNSServer: Source: ('192.168.0.102', 53249)
21:58:00 DNSServer: Domain: apple.com
21:58:00 DNSServer: ***forward request
21:58:05 DNSServer: DNS request received!
21:58:05 DNSServer: Source: ('192.168.0.102', 63800)
21:58:05 DNSServer: Domain: local
21:58:05 DNSServer: ***forward request
21:58:10 DNSServer: DNS request received!
21:58:10 DNSServer: Source: ('192.168.0.102', 58217)
21:58:10 DNSServer: Domain: www.apple.com
21:58:10 DNSServer: ***forward request
21:58:15 DNSServer: DNS request received!
21:58:15 DNSServer: Source: ('192.168.0.102', 58807)
21:58:15 DNSServer: Domain: iadsdk.apple.com
21:58:15 DNSServer: ***forward request
21:58:20 DNSServer: DNS request received!
21:58:20 DNSServer: Source: ('192.168.0.102', 53249)
21:58:20 DNSServer: Domain: apple.com
21:58:20 DNSServer: ***forward request
21:58:25 DNSServer: DNS request received!
21:58:25 DNSServer: Source: ('192.168.0.102', 63800)
21:58:25 DNSServer: Domain: local
21:58:25 DNSServer: ***forward request
21:58:30 DNSServer: DNS request received!
21:58:30 DNSServer: Source: ('192.168.0.102', 58217)
21:58:30 DNSServer: Domain: www.apple.com
21:58:30 DNSServer: ***forward request
21:58:35 DNSServer: DNS request received!
21:58:35 DNSServer: Source: ('192.168.0.102', 58807)
21:58:35 DNSServer: Domain: iadsdk.apple.com
21:58:35 DNSServer: ***forward request
21:58:40 DNSServer: DNS request received!
21:58:40 DNSServer: Source: ('192.168.0.102', 53249)
21:58:40 DNSServer: Domain: apple.com
21:58:40 DNSServer: ***forward request
21:58:45 DNSServer: DNS request received!
21:58:45 DNSServer: Source: ('192.168.0.102', 56706)
21:58:45 DNSServer: Domain: trailers.apple.com
21:58:45 DNSServer: ***intercept request
21:58:45 DNSServer: -> DNS response: 192.168.0.111
21:58:45 DNSServer: Source: ('192.168.0.102', 63800)
21:58:45 DNSServer: Domain: local
21:58:45 DNSServer: ***forward request
21:58:50 DNSServer: DNS request received!
21:58:50 DNSServer: Source: ('192.168.0.102', 58217)
21:58:50 DNSServer: Domain: www.apple.com
21:58:50 DNSServer: ***forward request
21:58:55 DNSServer: DNS request received!
21:58:55 DNSServer: Source: ('192.168.0.102', 58807)
21:58:55 DNSServer: Domain: iadsdk.apple.com
21:58:55 DNSServer: ***forward request
21:59:00 DNSServer: DNS request received!
21:59:00 DNSServer: Source: ('192.168.0.102', 53249)
21:59:00 DNSServer: Domain: apple.com
21:59:00 DNSServer: ***forward request
21:59:05 DNSServer: DNS request received!
21:59:05 DNSServer: Source: ('192.168.0.102', 56706)
21:59:05 DNSServer: Domain: trailers.apple.com
21:59:05 DNSServer: ***intercept request
21:59:05 DNSServer: -> DNS response: 192.168.0.111
21:59:05 DNSServer: Source: ('192.168.0.102', 61053)
21:59:05 DNSServer: Domain: p10-buy.itunes.apple.com
21:59:05 DNSServer: ***forward request
21:59:10 DNSServer: DNS request received!
21:59:10 DNSServer: Source: ('192.168.0.102', 61053)
21:59:10 DNSServer: Domain: p10-buy.itunes.apple.com
21:59:10 DNSServer: ***forward request
21:59:15 DNSServer: DNS request received!
21:59:15 DNSServer: Source: ('192.168.0.102', 61053)
21:59:15 DNSServer: Domain: p10-buy.itunes.apple.com
21:59:15 DNSServer: ***forward request
21:59:20 DNSServer: DNS request received!
21:59:20 DNSServer: Source: ('192.168.0.102', 63800)
21:59:20 DNSServer: Domain: local
21:59:20 DNSServer: ***forward request
21:59:25 DNSServer: DNS request received!
21:59:25 DNSServer: Source: ('192.168.0.102', 58217)
21:59:25 DNSServer: Domain: www.apple.com
21:59:25 DNSServer: ***forward request
21:59:30 DNSServer: DNS request received!
21:59:30 DNSServer: Source: ('192.168.0.102', 58807)
21:59:30 DNSServer: Domain: iadsdk.apple.com
21:59:30 DNSServer: ***forward request
21:59:35 DNSServer: DNS request received!
21:59:35 DNSServer: Source: ('192.168.0.102', 53249)
21:59:35 DNSServer: Domain: apple.com
21:59:35 DNSServer: ***forward request
21:59:40 DNSServer: DNS request received!
21:59:40 DNSServer: Source: ('192.168.0.102', 61053)
21:59:40 DNSServer: Domain: p10-buy.itunes.apple.com
21:59:40 DNSServer: ***forward request
21:59:45 DNSServer: DNS request received!
21:59:45 DNSServer: Source: ('192.168.0.102', 56706)
21:59:45 DNSServer: Domain: trailers.apple.com
21:59:45 DNSServer: ***intercept request
21:59:45 DNSServer: -> DNS response: 192.168.0.111
21:59:45 DNSServer: Source: ('192.168.0.102', 61053)
21:59:45 DNSServer: Domain: p10-buy.itunes.apple.com
21:59:45 DNSServer: ***forward request
21:59:50 DNSServer: DNS request received!
21:59:50 DNSServer: Source: ('192.168.0.102', 57353)
21:59:50 DNSServer: Domain: a2.mzstatic.com
21:59:50 DNSServer: ***forward request
21:59:55 DNSServer: DNS request received!
21:59:55 DNSServer: Source: ('192.168.0.102', 57353)
21:59:55 DNSServer: Domain: a2.mzstatic.com
21:59:55 DNSServer: ***forward request
22:00:00 DNSServer: DNS request received!
22:00:00 DNSServer: Source: ('192.168.0.102', 57353)
22:00:00 DNSServer: Domain: a2.mzstatic.com
22:00:00 DNSServer: ***forward request
22:00:05 DNSServer: DNS request received!
22:00:05 DNSServer: Source: ('192.168.0.102', 56706)
22:00:05 DNSServer: Domain: trailers.apple.com
22:00:05 DNSServer: ***intercept request
22:00:05 DNSServer: -> DNS response: 192.168.0.111
22:00:05 DNSServer: Source: ('192.168.0.102', 61053)
22:00:05 DNSServer: Domain: p10-buy.itunes.apple.com
22:00:05 DNSServer: ***forward request
22:00:10 DNSServer: DNS request received!
22:00:10 DNSServer: Source: ('192.168.0.102', 54850)
22:00:10 DNSServer: Domain: a2.mzstatic.com
22:00:10 DNSServer: ***forward request
22:00:15 DNSServer: DNS request received!
22:00:15 DNSServer: Source: ('192.168.0.102', 54850)
22:00:15 DNSServer: Domain: a2.mzstatic.com
22:00:15 DNSServer: ***forward request
22:00:20 DNSServer: DNS request received!
22:00:20 DNSServer: Source: ('192.168.0.102', 54850)
22:00:20 DNSServer: Domain: a2.mzstatic.com
22:00:20 DNSServer: ***forward request
22:00:25 DNSServer: DNS request received!
22:00:25 DNSServer: Source: ('192.168.0.102', 54850)
22:00:25 DNSServer: Domain: a2.mzstatic.com
22:00:25 DNSServer: ***forward request
22:00:30 DNSServer: DNS request received!
22:00:30 DNSServer: Source: ('192.168.0.102', 65504)
22:00:30 DNSServer: Domain: a5.mzstatic.com
22:00:30 DNSServer: ***forward request
22:00:35 DNSServer: DNS request received!
22:00:35 DNSServer: Source: ('192.168.0.102', 54850)
22:00:35 DNSServer: Domain: a2.mzstatic.com
22:00:35 DNSServer: ***forward request
22:00:40 DNSServer: DNS request received!
22:00:40 DNSServer: Source: ('192.168.0.102', 65504)
22:00:40 DNSServer: Domain: a5.mzstatic.com
22:00:40 DNSServer: ***forward request
22:00:45 DNSServer: DNS request received!
22:00:45 DNSServer: Source: ('192.168.0.102', 61053)
22:00:45 DNSServer: Domain: p10-buy.itunes.apple.com
22:00:45 DNSServer: ***forward request
22:00:50 DNSServer: DNS request received!
22:00:50 DNSServer: Source: ('192.168.0.102', 65504)
22:00:50 DNSServer: Domain: a5.mzstatic.com
22:00:50 DNSServer: ***forward request
22:00:55 DNSServer: DNS request received!
22:00:55 DNSServer: Source: ('192.168.0.102', 65504)
22:00:55 DNSServer: Domain: a5.mzstatic.com
22:00:55 DNSServer: ***forward request
22:01:00 DNSServer: DNS request received!
22:01:00 DNSServer: Source: ('192.168.0.102', 63800)
22:01:00 DNSServer: Domain: local
22:01:00 DNSServer: ***forward request
22:01:05 DNSServer: DNS request received!
22:01:05 DNSServer: Source: ('192.168.0.102', 65504)
22:01:05 DNSServer: Domain: a5.mzstatic.com
22:01:05 DNSServer: ***forward request
22:01:10 DNSServer: DNS request received!
22:01:10 DNSServer: Source: ('192.168.0.102', 54850)
22:01:10 DNSServer: Domain: a2.mzstatic.com
22:01:10 DNSServer: ***forward request
22:01:15 DNSServer: DNS request received!
22:01:15 DNSServer: Source: ('192.168.0.102', 56144)
22:01:15 DNSServer: Domain: a1.mzstatic.com
22:01:15 DNSServer: ***forward request
22:01:20 DNSServer: DNS request received!
22:01:20 DNSServer: Source: ('192.168.0.102', 56144)
22:01:20 DNSServer: Domain: a1.mzstatic.com
22:01:20 DNSServer: ***forward request
22:01:25 DNSServer: DNS request received!
22:01:25 DNSServer: Source: ('192.168.0.102', 56144)
22:01:25 DNSServer: Domain: a1.mzstatic.com
22:01:25 DNSServer: ***forward request
22:01:30 DNSServer: DNS request received!
22:01:30 DNSServer: Source: ('192.168.0.102', 56144)
22:01:30 DNSServer: Domain: a1.mzstatic.com
22:01:30 DNSServer: ***forward request
22:01:35 DNSServer: DNS request received!
22:01:35 DNSServer: Source: ('192.168.0.102', 65504)
22:01:35 DNSServer: Domain: a5.mzstatic.com
22:01:35 DNSServer: ***forward request
22:01:40 DNSServer: DNS request received!
22:01:40 DNSServer: Source: ('192.168.0.102', 56706)
22:01:40 DNSServer: Domain: trailers.apple.com
22:01:40 DNSServer: ***intercept request
22:01:40 DNSServer: -> DNS response: 192.168.0.111
22:01:40 DNSServer: Source: ('192.168.0.102', 56144)
22:01:40 DNSServer: Domain: a1.mzstatic.com
22:01:40 DNSServer: ***forward request
22:01:45 DNSServer: DNS request received!
22:01:45 DNSServer: Source: ('192.168.0.102', 54850)
22:01:45 DNSServer: Domain: a2.mzstatic.com
22:01:45 DNSServer: ***forward request
22:01:50 DNSServer: DNS request received!
22:01:50 DNSServer: Source: ('192.168.0.102', 65504)
22:01:50 DNSServer: Domain: a5.mzstatic.com
22:01:50 DNSServer: ***forward request
22:01:55 DNSServer: DNS request received!
22:01:55 DNSServer: Source: ('192.168.0.102', 52811)
22:01:55 DNSServer: Domain: a3.mzstatic.com
22:01:55 DNSServer: ***forward request
22:02:00 DNSServer: DNS request received!
22:02:00 DNSServer: Source: ('192.168.0.102', 56144)
22:02:00 DNSServer: Domain: a1.mzstatic.com
22:02:00 DNSServer: ***forward request
22:02:05 DNSServer: DNS request received!
22:02:05 DNSServer: Source: ('192.168.0.102', 52811)
22:02:05 DNSServer: Domain: a3.mzstatic.com
22:02:05 DNSServer: ***forward request
22:02:10 DNSServer: DNS request received!
22:02:10 DNSServer: Source: ('192.168.0.102', 61053)
22:02:10 DNSServer: Domain: p10-buy.itunes.apple.com
22:02:10 DNSServer: ***forward request
22:02:15 DNSServer: DNS request received!
22:02:15 DNSServer: Source: ('192.168.0.102', 52811)
22:02:15 DNSServer: Domain: a3.mzstatic.com
22:02:15 DNSServer: ***forward request
22:02:20 DNSServer: DNS request received!
22:02:20 DNSServer: Source: ('192.168.0.102', 52811)
22:02:20 DNSServer: Domain: a3.mzstatic.com
22:02:20 DNSServer: ***forward request
22:02:25 DNSServer: DNS request received!
22:02:25 DNSServer: Source: ('192.168.0.102', 63800)
22:02:25 DNSServer: Domain: local
22:02:25 DNSServer: ***forward request
22:02:30 DNSServer: DNS request received!
22:02:30 DNSServer: Source: ('192.168.0.102', 52811)
22:02:30 DNSServer: Domain: a3.mzstatic.com
22:02:30 DNSServer: ***forward request
22:02:35 DNSServer: DNS request received!
22:02:35 DNSServer: Source: ('192.168.0.102', 56144)
22:02:35 DNSServer: Domain: a1.mzstatic.com
22:02:35 DNSServer: ***forward request
22:02:40 DNSServer: DNS request received!
22:02:40 DNSServer: Source: ('192.168.0.102', 54218)
22:02:40 DNSServer: Domain: p10-buy.itunes.apple.com
22:02:40 DNSServer: ***forward request
22:02:45 DNSServer: DNS request received!
22:02:45 DNSServer: Source: ('192.168.0.102', 54218)
22:02:45 DNSServer: Domain: p10-buy.itunes.apple.com
22:02:45 DNSServer: ***forward request
22:02:50 DNSServer: DNS request received!
22:02:50 DNSServer: Source: ('192.168.0.102', 54218)
22:02:50 DNSServer: Domain: p10-buy.itunes.apple.com
22:02:50 DNSServer: ***forward request
22:02:55 DNSServer: DNS request received!
22:02:55 DNSServer: Source: ('192.168.0.102', 52811)
22:02:55 DNSServer: Domain: a3.mzstatic.com
22:02:55 DNSServer: ***forward request
22:03:00 DNSServer: DNS request received!
22:03:00 DNSServer: Source: ('192.168.0.102', 54218)
22:03:00 DNSServer: Domain: p10-buy.itunes.apple.com
22:03:00 DNSServer: ***forward request
22:03:05 DNSServer: DNS request received!
22:03:05 DNSServer: Source: ('192.168.0.102', 54850)
22:03:05 DNSServer: Domain: a2.mzstatic.com
22:03:05 DNSServer: ***forward request
22:03:10 DNSServer: DNS request received!
22:03:10 DNSServer: Source: ('192.168.0.102', 54218)
22:03:10 DNSServer: Domain: p10-buy.itunes.apple.com
22:03:10 DNSServer: ***forward request
22:03:15 DNSServer: DNS request received!
22:03:15 DNSServer: Source: ('192.168.0.102', 52811)
22:03:15 DNSServer: Domain: a3.mzstatic.com
22:03:15 DNSServer: ***forward request
22:03:20 DNSServer: DNS request received!
22:03:20 DNSServer: Source: ('192.168.0.102', 65504)
22:03:20 DNSServer: Domain: a5.mzstatic.com
22:03:20 DNSServer: ***forward request
22:03:25 DNSServer: DNS request received!
22:03:25 DNSServer: Source: ('192.168.0.102', 54218)
22:03:25 DNSServer: Domain: p10-buy.itunes.apple.com
22:03:25 DNSServer: ***forward request
22:03:30 DNSServer: DNS request received!
22:03:30 DNSServer: Source: ('192.168.0.102', 56144)
22:03:30 DNSServer: Domain: a1.mzstatic.com
22:03:30 DNSServer: ***forward request
22:03:35 DNSServer: DNS request received!
22:03:35 DNSServer: Source: ('192.168.0.102', 54218)
22:03:35 DNSServer: Domain: p10-buy.itunes.apple.com
22:03:35 DNSServer: ***forward request
22:03:40 DNSServer: DNS request received!
22:03:40 DNSServer: Source: ('192.168.0.102', 54850)
22:03:40 DNSServer: Domain: a2.mzstatic.com
22:03:40 DNSServer: ***forward request
22:03:45 DNSServer: DNS request received!
22:03:45 DNSServer: Source: ('192.168.0.102', 63172)
22:03:45 DNSServer: Domain: a1.mzstatic.com
22:03:45 DNSServer: ***forward request
22:03:50 DNSServer: DNS request received!
22:03:50 DNSServer: Source: ('192.168.0.102', 63172)
22:03:50 DNSServer: Domain: a1.mzstatic.com
22:03:50 DNSServer: ***forward request
22:03:55 DNSServer: DNS request received!
22:03:55 DNSServer: Source: ('192.168.0.102', 63172)
22:03:55 DNSServer: Domain: a1.mzstatic.com
22:03:55 DNSServer: ***forward request
22:04:00 DNSServer: DNS request received!
22:04:00 DNSServer: Source: ('192.168.0.102', 52811)
22:04:00 DNSServer: Domain: a3.mzstatic.com
22:04:00 DNSServer: ***forward request
22:04:05 DNSServer: DNS request received!
22:04:05 DNSServer: Source: ('192.168.0.102', 65504)
22:04:05 DNSServer: Domain: a5.mzstatic.com
22:04:05 DNSServer: ***forward request
22:04:10 DNSServer: DNS request received!
22:04:10 DNSServer: Source: ('192.168.0.102', 63172)
22:04:10 DNSServer: Domain: a1.mzstatic.com
22:04:10 DNSServer: ***forward request
22:04:15 DNSServer: DNS request received!
22:04:15 DNSServer: Source: ('192.168.0.102', 63172)
22:04:15 DNSServer: Domain: a1.mzstatic.com
22:04:15 DNSServer: ***forward request
^C22:04:17 PlexConnect: Shutting down.
22:04:18 WebServer: Shutting down.
22:04:20 DNSServer: Shutting down.
22:04:20 PlexConnect: shutdown
With the new router it looks like your subnet changed. I get this by the fact your ip_dnsmaster = 10.0.1.50 while everthing is now on 192.168.0.x
Thanks drewbie. Where/how can I update my ip_dnsmaster entry?
It’s in the settings.cfg file
You might also want to take the opportunity to update to the latest PlexConnect on Github as yours is fairly old code now and there have been improvements :)
Thanks. I will try both tonight. Do I edit the settings.cfg or settings.py ?
Setting.cfg
