Today I noticed weird issues…
I noticed nothing plays properly on the Plex PC App, just tries to load but never starts, I tested from Android app, that says content can’t be played, the Plex web interface Home page shows: No content available
Check your network connection and verify that any media servers are online, but Movies play with audio only…
I cleared cache on PMS and App on the NVShield, rebooted, still the same.
In the Settings of the Plex App on the Shield I see the PMS is missing!?
Any idea what gone wrong? I tested and everything play OK on the Plex app the Shield, but every other device is acting weird, and the fact the setting page don’t show the PMS icon is also odd!?
I would consider doing a fresh install of the PMS app and the whole NVShield form scratch, something I do every few months on the second Shield - but I would have to spend hours fixing all the cover art, titles, descriptions etc.
Is there any way to back all those settings up, so when I do a fresh install I can simply add it all back in one go?
From my experience I can’t just restore the configuration, but instead need to set everything back manually.
Thanks for any help or advice,
Andrew.
