Switching agent on a library appears to have no effect
Server Version#: 1.16.3.1402
I have changed the agent on my tv shows library from the movie database to tvdb, but it does not seem to have taken effect. I have done the plex dance, optimised the database and cleared the plugin support caches. Yet when I add new media, it still appears to be getting the metadata from the movie database, rather than tvdb. I cannot see any setting that suggests that the movie database should be used (it’s not set as a source in the tvdb agent settings). Am I doing something stupid, or is there a possible issue here?
The only thing of note is that I moved the install from one system to another (due to an operating system upgrade), following the instructions here: https://support.plex.tv/articles/201370363-move-an-install-to-another-system/
Even when you set TheTVDB as your primary agent, some data will be fetched from TMDB.
You can tell which agent is used with certainty, if you inspect the Plex XML info of any episode within the show.
Take a look at the content of the guid= property.
btw. it is often not necessary to change all shows over to the other agent. As long as all metadata are correect, you can simply leave it as-is. There is usually no downside to have a mixed library.
You can change the agent of a single show by performing the Fix Match procedure. Clicking on Search Options allows you to pick the agent which shall be used.
The newly added item is definitely showing that the metadata came from the movie database: guid="com.plexapp.agents.themoviedb://764/2/1?lang=en".
Does this indicate a problem (i.e. the setting is not being obeyed), or does it fail over to the movie database if the tvdb search fails for some reason?
Judging by the numbers, this is episode 1 from season 2, right?
You cannot change the agent on a by-season basis.
If you want to change the agent, you can only do so with the whole show at once.
If there is already season 1 of this show on your server, then every other season will use the same agent as season 1 already has.
