First off this issue is new but I dont know where along the way it broke. The flow is as follows:
- start sync either via the web GUI or on the system directly (tried all options for file transcoding sizes) for a .mts or .m2ts file.
- The “Conversion” page flashes a image of the item being synced then it disappears
- The system shows the title to be synced in “waiting on conversion”
It sits here indefinitely.
The logs show nothing of merit but I can post them if this isn’t a “known issue”. This used to work for me a time ago (about 6 months ago when I took road trip and needed to do this). I did try another solution posted on the forums and took a title with the issue and used TSMuxer on it to remove all “PGS” tracks with no luck.
Any ideas ? Need logs ?
Thanks!
