Sync transcoding error
I’ve been trying to sync some m4v files to my iPad, but they’re failing to transcode (they stream just fine). This is the error message I receive for them. Anyone know how I can fix the problem? I could just copy them directly to the iPad if I had to, but I prefer loading everything up in Plex for trips.
Aug 29, 2017 10:26:00.714 [0x112730000] DEBUG - MDE: About Time (2013): non-selected embedded subtitle stream 530792 cannot be direct-played
Aug 29, 2017 10:26:00.714 [0x112730000] DEBUG - MDE: About Time (2013): no direct play video profile exists for http/mp4/h264/ac3
Aug 29, 2017 10:26:00.727 [0x112730000] DEBUG - MDE: About Time (2013): non-selected embedded subtitle stream 530792 cannot be direct-played
Aug 29, 2017 10:26:00.728 [0x112730000] DEBUG - MDE: About Time (2013): non-selected embedded subtitle stream 530792 cannot be direct-played
Aug 29, 2017 10:26:00.762 [0x112730000] DEBUG - MDE: About Time (2013): selected media 0 / 238280
Aug 29, 2017 10:26:00.929 [0x113b4a000] DEBUG - [Universal] Using local file path instead of URL: /Volumes/Videos/Digital Copies/About Time (2013) (1080p).mp4
Aug 29, 2017 10:26:01.005 [0x113b4a000] DEBUG - Job running: EAE_ROOT=’/var/folders/q0/fj9tftgd4vndpl21nmx890wc0000gn/T/pms-097133f7-5490-4cd3-9325-a991fcc69c7e/EasyAudioEncoder’ FFMPEG_EXTERNAL_LIBS=’/Users/bluefrog/Library/Application\ Support/Plex\ Media\ Server/Codecs/798f007-1247-darwin-x86_64/’ XDG_CACHE_HOME=’/Users/bluefrog/Library/Caches/PlexMediaServer/’ XDG_DATA_HOME=’/Applications/Plex Media Server.app/Contents/Resources/’ X_PLEX_TOKEN=‘xxxxxxxxxxxxxxxxxxxx’ ‘/Applications/Plex Media Server.app/Contents/MacOS/Plex Transcoder’ ‘-codec:#0x02’ ‘h264’ ‘-codec:#0x03’ ‘ac3’ ‘-noaccurate_seek’ ‘-i’ ‘/Volumes/Videos/Digital/About Time (2013) (1080p).mp4’ ‘-noaccurate_seek’ ‘-i’ ‘/Users/bluefrog/Library/Caches/PlexMediaServer/Transcode/Sessions/plex-transcode-e6952f18-9072-4fd1-a495-0fe5dfbd8728-278e9f3e-e79b-47e8-8dd5-6da3dd7c222b/temp-0.srt’ ‘-map’ ‘0:#0x02’ ‘-metadata:s:0’ ‘language=eng’ ‘-codec:0’ ‘copy’ ‘-map’ ‘0:#0x01’ ‘-metadata:s:1’ ‘language=eng’ ‘-codec:1’ ‘copy’ ‘-copypriorss:1’ ‘0’ ‘-map’ ‘0:#0x03’ ‘-metadata:s:2’ ‘language=eng’ ‘-codec:2’ ‘aac_at’ ‘-ar:2’ ‘48000’ ‘-channel_layout:2’ ‘stereo’ ‘-b:2’ ‘193k’ ‘-map’ ‘0:#0x04’ ‘-metadata:s:3’ ‘language=fre’ ‘-codec:3’ ‘copy’ ‘-copypriorss:3’ ‘0’ ‘-map’ ‘0:#0x05’ ‘-metadata:s:4’ ‘language=eng’ ‘-codec:4’ ‘copy’ ‘-copypriorss:4’ ‘0’ ‘-map’ ‘0:#0x06’ ‘-metadata:s:5’ ‘language=eng’ ‘-codec:5’ ‘copy’ ‘-map’ ‘0:#0x07’ ‘-metadata:s:6’ ‘language=eng’ ‘-codec:6’ ‘mov_text’ ‘-map’ ‘0:#0x08’ ‘-metadata:s:7’ ‘language=spa’ ‘-codec:7’ ‘copy’ ‘-map’ ‘0:#0x09’ ‘-metadata:s:8’ ‘language=fre’ ‘-codec:8’ ‘copy’ ‘-map’ ‘0:#0x0a’ ‘-metadata:s:9’ ‘language=por’ ‘-codec:9’ ‘copy’ ‘-map’ ‘1:s:0’ ‘-metadata:s:10’ ‘language=eng’ ‘-codec:10’ ‘mov_text’ ‘-f’ ‘mp4’ ‘-map_metadata’ ‘-1’ ‘-map_chapters’ ‘-1’ ‘-movflags’ ‘+faststart’ ‘/Users/bluefrog/Library/Caches/PlexMediaServer/Transcode/Sync+/3000/a1/57888.mp4.temp’ ‘-y’ ‘-nostats’ ‘-loglevel’ ‘quiet’ ‘-loglevel_plex’ ‘error’ ‘-progressurl’ ‘http://127.0.0.1:32400/video/:/transcode/session/e6952f18-9072-4fd1-a495-0fe5dfbd8728/278e9f3e-e79b-47e8-8dd5-6da3dd7c222b/progress’
