Synology DS1618+ Plex Media Server Fails to Run
No I do not understand “Nippon Television”
Your home LAN is using their IP address ranges. This isn’t allowed and why PMS isn’t working right.
To make it all work right, you need to make your home LAN compliant with a real RFC-1918 “Private Network”.
This means something either in the 10.x.x.x/24, 172.16.x.x->172.31.x.x/24, or 192.168.x.x/24 ranges.
If everything is assigned an address from your router via DHCP, make the master change there and then restart everything to pick up their new addresses.
It will be messy but when done, everything will work.
[chuck@lizum plex.175]$ whois 167.169.12.14
[Querying whois.arin.net]
[Redirected to whois.apnic.net]
[Querying whois.apnic.net]
[whois.apnic.net]
% [whois.apnic.net]
% Whois data copyright terms    http://www.apnic.net/db/dbcopyright.html
% Information related to '167.169.0.0 - 167.169.255.255'
% Abuse contact for '167.169.0.0 - 167.169.255.255' is 'hostmaster@nic.ad.jp'
inetnum:        167.169.0.0 - 167.169.255.255
netname:        NTVNET
country:        JP
descr:          NIPPON TELEVISION NETWORK CORPORATION
admin-c:        NJ128-AP
tech-c:         NJ128-AP
status:         ASSIGNED PORTABLE
notify:         apply@iij.ad.jp
mnt-by:         MAINT-JPNIC
mnt-irt:        IRT-JPNIC-JP
last-modified:  2015-12-01T22:25:14Z
source:         APNIC
irt:            IRT-JPNIC-JP
address:        Urbannet-Kanda Bldg 4F, 3-6-2 Uchi-Kanda
address:        Chiyoda-ku, Tokyo 101-0047, Japan
e-mail:         hostmaster@nic.ad.jp
abuse-mailbox:  hostmaster@nic.ad.jp
admin-c:        JNIC1-AP
tech-c:         JNIC1-AP
auth:           # Filtered
mnt-by:         MAINT-JPNIC
last-modified:  2017-10-18T10:21:54Z
source:         APNIC
person:         Nobuyuki Jo
nic-hdl:        NJ128-AP
e-mail:         n-jo@ntv.co.jp
address:        1-6-1 Higashi-shimbashi, Minato-ku,Tokyo 105-7444,Japan
phone:          +81-3-6215-2542
fax-no:         +81-3-6215-2541
country:        JP
mnt-by:         MAINT-JPNIC
last-modified:  2008-09-04T07:50:20Z
source:         APNIC
% This query was served by the APNIC Whois Service version 1.88.15-47 (WHOIS-US4)
[chuck@lizum plex.176]$
Hello
it is not possible to claim the server with its sub-network. Use a subnet donate by ChuckPA
OK I will change my entire network IP and try it again then.
what is the default for the modem/router?
Most are in the 192.168.x.x block.
If it has a preferred default, I recommend going with whatever it recommends. Your ISP will have wanted it a certain way for some specific reason.
