To downgrade:
- Uninstall the app, Select the Uninstall Only option in the menu.
- Now install the lower version.
- When PMS starts, give it an extra 30 seconds or so for it to adjust itself internally.
To downgrade:
Just upgraded to DSM 7 from DSM 6 and Iâve clearly done something wrong.
Set up:
DS 918+
DSM 7.1-42661
PlexMediaServer-1.26.0.5715-8cf78dab3-x86_64_DSM7
Itâs working, in that I have been able to add libraries and Plex is currently indexing them. This is of course taking ages.
I have clearly missed a step in which my old library in the Plex shared folder gets imported. Itâs still there and i also have a PlexMediaServer shared folder.
If someone could please point me to instructions to reinstall Plex so that it picks up the old indices, thatâd be awesome.
It sounds like the permissions on the âPlexâ shared folder were manually set at some point and when upgrading to DSM 7, the new installer (because it isnât administrator anymore) couldnât read the shared folder.
The remedy for this, assuming your DSM 6 -based server is fully intact in the âPlexâ shared folder, is:
Now follow âScenario 2â as shown here.
Your goal is to update the permissions for all folders and files in the âPlexâ share and grant âPlexMediaServerâ (the new service username) Full Control of all files.
Be patient with this .. It will take 2-3 minutes for each 1000 media items you have index by PMS
Many thanks, Iâll give that a try.
I hope youâre recovering well from Covid BTW.
I am , I hope, almost over the lingering cough.
Itâs not been fun. Thanks for the kind words.
As for the installation & migration,
It does take time. We donât have âadminâ privileges on DSM 7 (Syno changed that).
We canât force anything to happen / fix permissions like we could with DSM 6 so I have to rely on following the procedures built into the new installer.
I hope you like the install package. Itâs a full rewrite, supporting 8 languages now, with menus, and gives context-sensitive feedback as it does itâs job
Covid: good to hear. Nasty lil sod that virus.
Took a few hours (~85,000 files so I was expecting that) but itâs all running sweetly now. Install package made it very easy â canât ask for better than that.
Thanks for your help!
Excellent.
How do you like the new menus?
Are they clear and easy to understand?
I thought today, there hasnât been a (Synology) PMS update for awhile, checked my server and it says
Version 1.25.8.5663 Checking for Updates
It never gets any further than Checking
I see that 1.26.0.5715 is available - am I OK to install this manually?
1.25.9 is public release.
1.26.0 is beta
You should see at least one of them . Is DSM communicating correctly to the internet? (Everything plays and authenticates OK otherwise?)
You can update to whichever version you wish
I manually downloaded 1.26.0.5715 but then my server âcaught upâ and allowed me to officially download 1.26.0.5715 so I went ahead and installed that - my server now says it is at 1.25.9.5721.
@ChuckPa It says in the installation instructions not to install DSM 7.1 since beta versions is not supported. But now it seems that 7.1 is released so just wondering if it safe to upgrade or we should wait? Iâm already on 7.0 with plex running.
Thanks!
Now that DSM 7.1 is public release, youâre good to go.
Itâs been our experience that DSM 7.x beta releases are not something we can support.
I went crazy trying to support DSM 7.0 throughout its different beta releases.
It was decided we will extend not supporting BETA OS releases to NAS products.
***Edit - all sorted had to manually install the latest DSM 7.1-42661, My DSM was telling me I had the latest DSM when it wasnâtâŠ
***Original post
DSM version: DSM 7.0.1-42218 Update 3
NAS: Synology DS418j
CPU: Realtek RTD1293 SoC
I updated to DSM 7 but not sure what version i was on before, I hadnât updated for a long time.
It all seemed to go smoothly and I can access my network shares via windows but plex no longer works.
Plex server isnât installed on my NAS. Iâve tried downloading all the synology (DSM 7) files from here: https://www.plex.tv/en-gb/media-server-downloads/
I wasnât sure which one i needed so Iâve tried manually installing them via the package centre but they all say:
âThis package is not supported on the platform of disk station or is incompatible with the current version of DSMâ
Not sure what to do. Is my NAS incompatible with the latest plex server, it is quite old.
For the DS418j, you want the ARMv8 (64 bit) package.
I have one of these which I use as my development system.
Suddenly Plex stopped working, I didnât updated it or made any changes. It simply stopped working. Attaching here the logs hoping someone can help figure out whatâs wrong.
Logs.zip (3.7 MB)
I seem to be unable to update Plex on my NAS (DS 920+) anymore.
Already in the first step of the update process (which is only uploading the file), the upload thingy is stuck on Processing⊠Please WaitâŠ
I have waited for hours, but it doesnât continue any further. When I close the browser, there is no indication I ever tried updating.
I stopped PMS before running the update again, but that didnât prove to be a solution. Help! I donât know where to start solving this issue?
Patrick,
âProcessingâ will occur if youâre updating from an older version of PMS (any DSM 7 version prior to 1.22.4.4973).
What itâs doing is completing the restructuring of the âPlexMediaServerâ shared folder.
I did this because , after DSM 7.0 was âFinal Releaseâ, I could complete the restructuring / moving from the âPlexâ shared folder and put everything in its new location (PlexMediaServer/AppData)
As long as you donât interrupt this, it will complete naturally.
I wish there was a way to have DSM / Package Center print a popup warning before starting but I could never figure out how to accomplish it.
Dear @ChuckPa
Thanks for your quick reply and explanation.
It is still running now, for over 24 hours. I have libraries of a little less than 1TB combined. I also see no real activity on the NAS in CPU usage. Iâm wondering if this is correct. Thanks in advance for your advice!
Btw Iâm updating from a version 24 to 26.0. I installed 24 from scratch (so not as an update).
Same thing!!! Last week it was working in the AM and then it was not in the PM. My NAS says its running and I can access http://192.168.254.5:32400/web/index.html#!/ but it does not even show that it is a Plex server. I get a â+ Your Mediaâ option to install a server http://192.168.254.5:32400/web/index.html#!/get-plex-media-server
Itâs possible your browser got stuck. (Iâve seen that happen).
Open another tab to the Diskstation.
Next open the Resource Monitor - Task Manager - Processes
Sort the list alphabetically by name (left column).
Is Plex running ?
