Server Version#: Cannot access
Player Version#: Cannot access
Cannot access.
I just installed Plex form the web downloads link at plex.tv. I installed and was at the plex main screen. I closed the app then went to the Synonlgy server and tried to reopen it. I received NOT Authorized You do not have access to this server.
Reinstall the package – “Plex Claim Token” option
Click “Get Claim Token” → Browser opens
COPY the token
return to installer GUI window
PASTE token into the box.
Continue installing normally.
This adds 20-30 seconds to the install time. The installer negotiates new credentials for you with Plex.tv and then updates your Plex server before starting it.
@ChuckPa so when I go to settings - server - troubleshooting I do not see anywhere that I can download logs. I have not flipped anything, I just typed in logs in my synology screen bc that is what I thought you were needing to see. Super frustrating bc I followed those guides to the T. Is there a 5th grader way to get you these logs you need?
I do see that I have 2 servers still in my authorized devices list, one from 6.2.4 and the other from 7.0.1
@ChuckPa so I was able to get to where it wants me to set up a new server… but I dont want to do that right? I would like to keep all of my old libraries and metadata.
@ChuckPa I ended up just setting up a new server but now when I bring my old filles over it is missing 8 tv series and about 30 movies. Any easy way to get plex to recognize all of them?
For instance Sons Of Anarchy would be named Sons.Of.Anarchy.S01E01, then so forth from there. Movies would be like Above.The.Rim but have recently started adding the year after the title.
@ChuckPa OK I will try that. What is the best setting for Plex as far as matching goes? Like in the Agent section. Right now mine has personal media and then local media. Could that be why I am getting a ton of wrong matches? Before going over to DSM7 I did not have nearly this much trouble on matching.
